.NET
Hallex
Message 11 of 14 (203 Views)
Re: Fatal Exception when running code
05-25-2012 10:56 AM in reply to: bkenyon13
Good point
Thanks for the sharing with community
Cheers :smileyhappy:
~'J'~
New Member
ChristianBlei7416
Message 12 of 14 (186 Views)
05-26-2012 02:40 AM in reply to: bkenyon13
does not the "Exit for" without any condition cause the code to leave the loop inside the first round? Maybe you are not going to reach your problem anymore......
Christian Blei
Active Contributor
bkenyon13
Message 13 of 14 (179 Views)
05-26-2012 08:14 AM in reply to: ChristianBlei7416
what I found was while this solved the fatal error it stopped copying the pagesetups.
So I did some troubleshooting and realized the the curps.dispose was the issue with it not copying the pagesetup
however I also discovered that if I removed the exit for and/or the curps.dispose I would get the fatal error again.
so in order for my code to work and copy the pagesetups without giving me the fatal error I had to stop/unload the curps without using curps.dispose and exit for.
so a long story somewhat short I did this:
using curps as plotsettings = new plotsettings(false)
(did work)
end using
This allowed me to copy the pagesetups as I wanted and not get a fatal error in the resulting code I removed all exit for's.  What I learned from this is that you have to make sure that everything gets unloaded even the littlest thing still hanging out there can cause an error.
Hope this helps.
Bauron
Message 14 of 14 (113 Views)
06-24-2013 07:44 PM in reply to: bkenyon13
Hello
I understand that this thread is over a year old, and am not sure if posting here will still elicit a response.
If it does not, I will post again.
it seems that kenyon is saying that you havet to dispose of the variables as soon as you are done using it.
That means assigning the plot setting to a variable is out of question?
I am trying to write a function that simply returns the plot settings to the mother routine, based on the paper size the user picks in a form.
I am having no luck in preventing the autocad crash once it cycles through two or three of the page setups.
Intially, it cycled through all layout page setups.
And trying to get it to read any page setup that is not in a layout is out of the question.
Please help.
Bauron
