.NET
Active Member
Akanath
Message 1 of 5 (365 Views)
FATAL ERROR with Core Console (Automate plotting)
365 Views, 4 Replies
11-21-2012 03:05 AM
I'm trying to automate plotting DWG to make PDF.
My File :
My DWG has one model and one paperspace with view of the model.
Each view can have many viewport and has a cartridge.
My Goal :
I want a PDF File. One view per page.
My method :
I have an intermediate step, which create many Postscript File(One per View)
The second step use GhostScript to concate PS Files in a PDF.
The steps:
1st step : Read DWG File to create script file, in order to automate plotting with AccoreConsole.exe. My method give me the point for plotting in a window with both corner.
2d step : Use the Script File and Software like (TRUEVIEW or ACCORECONSOLE(Autocad 2013) to create PS Files.
Last step : Run GhostScript to make my PDF File as I wish.
Problem :
Old method
It works with DWGTrueView, but I would like a silent mode for executing.
Solution ==> use AccoreConsole.exe include in Autocad 2013
New method
Using Accoreconsole with a ProcessStartInfo, I realized that accoreconsole.exe can raised error that DWGTrueView didn't raised.
It works with some files, but sometimes, it's crashed, and I don't understand why.
Do you have any idea ?
For exemple, a file that succeed with DWGTrueView
Active Member
Akanath
Message 2 of 5 (326 Views)
Re: FATAL ERROR with Core Console (Automate plotting)
11-26-2012 01:57 AM in reply to: Akanath
Is it possible that the object number in file has any limit ?
If it's the problem, can we delete this limit ?
ADN Support Specialist
Balaji_Ram
Message 3 of 5 (292 Views)
12-03-2012 08:27 AM in reply to: Akanath
I havent come across any such limit.
Can you please share a non-confidential drawing along with the steps to reproduce the crash ?
Thank you.
Balaji
Developer Technical Services
Autodesk Developer Network
Active Member
Akanath
Message 4 of 5 (288 Views)
12-03-2012 08:40 AM in reply to: Akanath
Hello
This is my Dwg File and his associated script.
The plot don't work and catch a FATAL ERROR.
Thank you for you reply.
For information, my virtual printer makes postscript file.
My script who don't work as Attachement :
_plot y
COMETE_PS.pc3
COMETE (420.00 x 297.00 mm)
m
L
_N
_w
0,2400
387,2674
f
c
_n
_n
_y
_y
_n
_y
C:\test.PS
_n
y
quit
Active Member
Akanath
Message 5 of 5 (264 Views)
12-04-2012 01:41 AM in reply to: Akanath
It seems not to work with my postscript (420*297 mm) printer.
But it works with a PDF printer.
I work on it.
