.NET
.NET
Active Contributor
bkenyon13
Message 1 of 2 (102 Views)
fatal error resolved but still having issue
102 Views, 1 Replies
05-25-2012 09:44 AM
I found the line that was causing the fatal error that I was getting, but I am now having another issue.
I have code that looks as follows:
For Each psent As DBDictionaryEntry In psd
                            id = psd.GetAt(psent.Key)
                            Dim ps As PlotSettings = id.GetObject(OpenMode.ForRead)
                            Dim curps As PlotSettings = New PlotSettings(False)
                            curps.CopyFrom(ps)
                            curps.AddToPlotSettingsDictionary(db)
                            curps.DowngradeOpen()
                            trns.Commit()
                            curps.Dispose()
                            Exit For
                        Next
 This will only copy one pagesetup, how ever I have multiple pagesetups that I need to have copied. I can accomplish that by removing the curps.dispose().
however if I remove that then I start getting the fatal error back.
is there a way that I can close the curps plotsettings without using dispose or close?
finally figured it out.
I used:
using curps....
(did work)
end using
this eliminated the fatal error and also copied all the page setups
Active Contributor
bkenyon13
Message 2 of 2 (99 Views)
Re: fatal error resolved but still having issue
05-25-2012 10:09 AM in reply to: bkenyon13
I used:
using curps....
(did work)
end using
