Hi
I have got a button that i have changed the F1 to open my open CHM File
The only problem is it opens the file but looks for htm and the files within mine chm are html
Is there any way of telling in to look for the html file and not just htm?
Button.HelpSource = New Uri(Install_Loc) Button.HelpTopic = "store"
Basicaly is looks for the location of the help file
and then the name of the page which in the example above is "store"
And then opens the chm file with the store page but at the moment it is doing "store.htm" and not html
Thanks In Advance
James
It sounds like you have an incorrect topic mapping in your help file.
My help file works fine
Its just that the files behind it have been compiled as HTML and not htm
We have tested it by chnaging one of the pages to be htm to see if it would work and it does it opens on the correct page
as it is now a htm file
Its just adding the extension .htm on the end of the topic and i want it to add html
or its the only option to convert all the pages to htm ?
@makepeace1 wrote:or its the only option to convert all the pages to htm ?
Other things to try:
1) Add the .html extension to your topic string.
2) Create or correct your help file's keyword/topic map.
