.NET
.NET
Active Member
0 Kudos
Post 1 of 5
Extracting dwg drwaing file(.dwg) data in visual studio 2010(using c# asp.net)
792 Views, 4 Replies
05-03-2012 01:01 AM
1)I need to extract the data of an .dwg file using Visual studio and AUTOCAD. Here i need to pass the data from autocad to my asp.net application when i load the .dwg file into AUTOCAD and click "Extract" Custom menu.
2)How to add "Extract" custom menu to Autocad Application and how to open my asp.net application after clicking on it
Distinguished Mentor
91 Kudos
Post 2 of 5
Re: Extracting dwg drwaing file(.dwg) data in visual studio 2010(using c# asp.ne
05-03-2012 09:18 AM in reply to: hmshettikera
I think you have to be more explicit:
1.- What kind of data?,  a dwg file can contain a lot of different kind of data: geometry, attributes, anotations, text, hyperlinks, dblinks, images, time stamp, etc. So you need to make clear what kind of data you need to extract from a dwg file.
2.- Output format, you say that a ASP .NET application will comsume the data, what format your data  need to feed that application.
3.- There are several ways to start an application from managed code:  you can embed a browser (Webbrowser control ) in a form, you can start a browser from code (via ShellExecute or other mechanism)
4.- To add a menu (or menu group) to AutoCAD from code you can check this link: http://through-the-interface.typepad.com/through_the_interface/2010/04/adding-to-autocads-applicatio...
5.- Platform, better you say in what platform are you working, or deploying the application to. AutoCAD or vertical version, OS, 32/64 bits, and VS version.
Gaston Nunez
Active Member
0 Kudos
Post 3 of 5
05-04-2012 07:07 AM in reply to: gasty1001
Thank you for reply.
I am a .Net developer(c# asp.net) and usually we work on .Net framework 4.0(Visual Studio 2010).
Our aim is to to extract the geometry, attributes, anotations, text, hyperlinks fields when user clicks a Custom menu( say "Extract Now" menu item).
1)User opens .dwg file in Autocad 2012/13
2) He can click a custom menu and after click, all data of that image should be exported to .net application(preferably Dotnet web application)
3) user can see on the browser what data he has extracted and which data wants to save in sql server
I hope this forum is right place to ask this question
1,210 Kudos
Post 4 of 5
05-04-2012 07:18 AM in reply to: hmshettikera
For questions ... yes
For getting it done for you .... no :smileyhappy:
And as a short answer, there is no function for "extract my drawing to sql-server", if that was the question.
Well, one option may be if you think about GIS-data and you have Map3D or Civil3D (having Map3D-functionality built in) as your vertical product. If so, let us know, for now I don't see any sysinfo what you are using currently.
At least you have to write your own export-engine. And that's not a one-day-job as there are a lot of different geometry-types within AutoCAD plus a lot of different object-types used in drawings created by vertical AutoCAD-based products (ACA, MEP, Civil3D, Map3D) and last-but-not least every developer may have written his own object-types.
At the moment I stop here, would be great to know a little bit more detailed the goals you'd like to get done.
- alfred -
Alfred NESWADBA
91 Kudos
Post 5 of 5
05-04-2012 07:22 AM in reply to: hmshettikera
I guess you are new to AutoCAD, my advice is to check the data extraction command in AutoCAD (type DATAEXTRACTION at the command line) before to code a single line in .NET. Maybe you only need to process the output file generated, and not to learn a new API.
Gaston Nunez
