.NET
Extracting BOM from AutoCAD using C#
16 REPLIES 16
Message 1 of 17
4936 Views, 16 Replies
Hello All,
I am doing a customization project in AutoCAD 2012 using C#.net.
My objective is to extract BOM table from an AutoCAD drawing using c# programming.
I am trying to create a custom menu in AutoCAD which will have the export BOM functionality.
Since I am new to C# programming I am finding it difficult to form the code.
Any sort of help is appreciated.
Thanks in advance.
Regards
Arindam Basu
16 REPLIES 16
Message 2 of 17
hgasty1001
What about dataextraction command?, it can be automated , see this link: Dataextraction , also it's easy to read from a table and write its data to excel, see this link:Export Table , and Dataextraction API .
Gaston Nunez
Message 3 of 17
Hallex
Can you upload small picture to see the result
of this program?
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 4 of 17
in reply to: hgasty1001
Hi Gaston
The data extraction tool does not export my BOM table.
I am attaching a sample drawing with a BOM table on it.
The task that export function does when right clicking on any table, i have to do that with the help of C# code.
My objective is to create a new custom menu in any toolbar of AutoCAD and link the export functionality to that menu.
Message 5 of 17
Alexander.Rivilis
Maybe _TABLEEXPORT can help you.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 6 of 17
in reply to: Alexander.Rivilis
Exactly the function which _TABLEEXPORT does, i have to do that with the help of a custom menu or by creating a custom action in the quick access toolbar. after creating the action i have to link the _TABLEEXPORT functionality to that custom action.
can anybody help me with the code to create such a custom menu or custom action?
Arindam Basu
Message 7 of 17
Alexander.Rivilis
I do not understand why you need to use .NET API if you can manually add the command to the menu (CUI), save as a partial menu and load it when needed.
Expert Elite Member
Message 8 of 17
Thanks Alexander,
I understand what you are telling is also a way to fulfill my objective.
But I was looking for a way other than customizing it through UI.
Anyway,
Can you explain me further the steps to save my new custom menu as a partial menu and load it when needed.
I have created a new menu and also loaded it with the _TABLEEXPORT command,
but each time I am opening AutoCAD it is showing the menu.
If it is possible to change it to a partial menu and load it as and when required please suggest the way for it.
Arindam
Message 9 of 17
Alexander.Rivilis
You can do it many ways.
For example: http://through-the-interface.typepad.com/through_the_interface/2010/04/adding-to-autocads-applicatio...
Expert Elite Member
Message 10 of 17
Hallex
Please check this code
http://www.acadnetwork.com/topic-198.0.html
Message 11 of 17
in reply to: Hallex
Hey Hallex,
I cant access the link you've mentioned.
Only registered members are allowed to access this section.
And registration is failing everytime.
Kindly post the code here, if u please.
Thanks in advance.
Message 12 of 17
Hallex
The real world example, based on the drawing from there:
http://forums.augi.com/showthread.php?136467-lisp-table-help&p=1167872&viewfull=1#post1167872
Message 13 of 17
in reply to: Hallex
Hi Halex,
The link you provided helped a lot.
I found the code in lisp.
The TableXport.lsp code works perfect.
Thanks for sharing.
Arindam Basu
Message 14 of 17
Hallex
You're welcome, Arindam
Cheers 🙂
Message 15 of 17
in reply to: Hallex
hi,
i have attched a sample drawing here which i need to extract total bom from drawing like (tee joint, reducer,dummy plate, socket fittings etc..) which is totaly into fire fighting, can you help me out in this.....
Message 16 of 17
amitnkukanur
The bom you want to extract is block of with attributes or exploded texts
Senior Software Engineer
Message 17 of 17
in reply to: Hallex
hi what is the dll used?
”Boost
