.NET
Active Member
Arindam_Basu
Message 1 of 14 (1,027 Views)
Extracting BOM from AutoCAD using C#
1027 Views, 13 Replies
04-17-2013 05:09 AM
Hello All,
I am doing a customization project in AutoCAD 2012 using C#.net.
My objective is to extract BOM table from an AutoCAD drawing using c# programming.
I am trying to create a custom menu in AutoCAD which will have the export BOM functionality.
Since I am new to C# programming I am finding it difficult to form the code.
Any sort of help is appreciated.
Thanks in advance.
Regards
Arindam Basu
Valued Mentor
gasty1001
Message 2 of 14 (1,011 Views)
Re: Extracting BOM from AutoCAD using C#
04-17-2013 06:40 AM in reply to: Arindam_Basu
What about dataextraction command?, it can be automated , see this link: Dataextraction , also it's easy to read from a table and write its data to excel, see this link:Export Table , and Dataextraction API .
Gaston Nunez
Hallex
Message 3 of 14 (976 Views)
04-17-2013 09:35 PM in reply to: Arindam_Basu
Can you upload small picture to see the result
of this program?
Active Member
Arindam_Basu
Message 4 of 14 (975 Views)
04-17-2013 09:35 PM in reply to: gasty1001
Hi Gaston
The data extraction tool does not export my BOM table.
I am attaching a sample drawing with a BOM table on it.
The task that export function does when right clicking on any table, i have to do that with the help of C# code.
My objective is to create a new custom menu in any toolbar of AutoCAD and link the export functionality to that menu.
Moderator
Alexander.Rivilis
Message 5 of 14 (964 Views)
04-17-2013 10:51 PM in reply to: Arindam_Basu
Maybe _TABLEEXPORT can help you.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Member
Arindam_Basu
Message 6 of 14 (960 Views)
04-17-2013 11:00 PM in reply to: Alexander.Rivilis
Exactly the function which _TABLEEXPORT does, i have to do that with the help of a custom menu or by creating a custom action in the quick access toolbar. after creating the action i have to link the _TABLEEXPORT functionality to that custom action.
can anybody help me with the code to create such a custom menu or custom action?
Arindam Basu
Moderator
Alexander.Rivilis
Message 7 of 14 (947 Views)
04-18-2013 03:32 AM in reply to: Arindam_Basu
I do not understand why you need to use .NET API if you can manually add the command to the menu (CUI), save as a partial menu and load it when needed.
Active Member
Arindam_Basu
Message 8 of 14 (941 Views)
04-18-2013 04:58 AM in reply to: Alexander.Rivilis
Thanks Alexander,
I understand what you are telling is also a way to fulfill my objective.
But I was looking for a way other than customizing it through UI.
Anyway,
Can you explain me further the steps to save my new custom menu as a partial menu and load it when needed.
I have created a new menu and also loaded it with the _TABLEEXPORT command,
but each time I am opening AutoCAD it is showing the menu.
If it is possible to change it to a partial menu and load it as and when required please suggest the way for it.
Arindam
Moderator
Alexander.Rivilis
Message 9 of 14 (936 Views)
04-18-2013 05:31 AM in reply to: Arindam_Basu
You can do it many ways.
For example: http://through-the-interface.typepad.com/through_the_interface/2010/04/adding-to-autocads-applicatio...
Hallex
Message 10 of 14 (923 Views)
04-18-2013 08:58 AM in reply to: Arindam_Basu
Please check this code
http://www.acadnetwork.com/topic-198.0.html
