.NET
.NET
Active Member
SuperFly
Message 1 of 7 (315 Views)
Extract Properties from AcadEntity
315 Views, 6 Replies
09-22-2005 02:03 PM
I'm trying to populate textboxes in a Windows App. with properties of a 3DSolid. I got the app to open a document with the solid and I can assign the solid to a variable - but I get an exception when I try to assign the 3DSolid's properties to variables. I can see the correct value in the Watch window though. For instance: Assume MySS is a selection set with 1 element being the solid.
Dim MySolid as Acad3DSolid
MySolid = MySS.Item(0)
Dim MyVolume as Double = MySolid.Volume
Last line is no good ==> Unhandled exception "System.EngineExecutionException"
but when I break and enter MySolid.MyVolume in the Watch window - it shows the correct value and says it's type "Double"
Could there be something wrong with my refs?
I've got AutoCad 2006 Type Library and AutoCAD/ObjectDBX Common 16.0 Type Library referenced.
Please help - this is driving me nuts.
*Norman Yuan
Message 2 of 7 (315 Views)
Re: Extract Properties from AcadEntity
09-22-2005 04:55 PM in reply to: SuperFly
If it is VB6, your code
looks fine. I am not sure, though, in VB.NET, implicit type conversion is
still OK. Since MySS.Item(0) returns an object, if you use C#, you
definitely need to cast it into Acad3DSolid:
MySolid=(Acad3DSolid)MySS.Item[0];
So, just try this in your VB.NET:
MySolid=CType(MySS.Item(0), Acad3DSolid)
wrote in message news:4964775@discussion.autodesk.com...
being the solid.
Library referenced.
Active Member
SuperFly
Message 3 of 7 (315 Views)
09-23-2005 05:37 AM in reply to: SuperFly
Yeah, I'm in .NET - I tried the conversion, but still no good. The line:
gives this exception:
An unhandled exception of type 'System.Runtime.InteropServices.COMException' occurred in MyProgram.exe
Additional information: Invalid argument color in IAcadEntity::smileytongue:ut_Color
Could this be a bug? Anyone try to do this before?
*Tony Tanzillo
Message 4 of 7 (315 Views)
09-23-2005 07:13 AM in reply to: SuperFly
Is your code changing the color of the object somewhere?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4965236@discussion.autodesk.com...
Active Member
SuperFly
Message 5 of 7 (315 Views)
09-23-2005 07:19 AM in reply to: SuperFly
No - I'm not altering the entity at all. I open a file with a pre-existing solid, assign it to a variable using a selection set, and then just try to grab the volume. The color thing is very confusing. By the way - the file is .DXF - could this have anything to do with it? I'll try to save it as a dwg and try again.
Active Member
SuperFly
Message 6 of 7 (315 Views)
09-23-2005 08:15 AM in reply to: SuperFly
Update: I tried changing to a DWG file to no avail. However, I also tried creating the solid from scratch entirely through my .NET app - in this case, the resulting solid properties were assignable. This however is not an option because of speed constraints - wondering if this enlightens anyone to what's going on in my pre-existing solid case.
Distinguished Contributor
fantum
Message 7 of 7 (315 Views)
09-23-2005 09:17 AM in reply to: SuperFly
Sounds like your existing solid may have nothing in it. Where did you get it?
Never mind. I see where you managed to get a volume in the watch window. Message was edited by: fantum
