.NET
Showing results forĀ
Did you mean:Ā
Externally loading an assembly into running ACAD app. namespace
9 REPLIES 9
Message 1 of 10
530 Views, 9 Replies
I need to load .NET DLL into running ACAD
application namespace, but externally - out of another process (Startup module,
source excerpt below). How possibly can I get it working?
Startup module (that fires ACAD up) references
following libs found in GAC:
- Autodesk.AutoCAD.Interop.dll
Autodesk.AutoCAD.Interop.Common.dll
size=2>
size=2>Imports
''' Startup
module that fires up ACAD
size=2>Module
Startup
Sub
Main()
color=#008080>''' Start ACAD the easy way... No error
checking...
size=2>    Dim
oACAD
color=#0000ff size=2>As
Autodesk.AutoCAD.Interop.AcadApplication
    oACAD =
New
color=#008080>''' >>> I simply don't want to load assembly
via Lisp here.
>>> I've been thinking of using P/Invoke, still don't know what
set of
acad.exe functions is responsible for netload-ing an assembly.
Using a bit more managed approach is even more welcome
oACAD.ActiveDocument.SendCommand( _
    "(command "
+ Chr(34) + _
    "NETLOAD" +
Chr(34) + " " + Chr(34) + _
"TCGDotNet16.dll" + Chr(34) + ")" + vbLf)
End
size=2>Sub
color=#0000ff size=2>End
color=#0000ff size=2>Module
color=#0000ff size=2>Thanks for any
suggestion on that matter.
color=#000000>Regards,
color=#0000ff size=2>Maksim
Sestic
9 REPLIES 9
Message 2 of 10
Didn't you read my previous reply on this?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Maksim Sestic" wrote in message news:4963788@discussion.autodesk.com...
I need to load .NET DLL into running ACAD application namespace, but externally - out of another process.......
Message 3 of 10
Sorry, my previous reply doesn't explain much.
Are you sure you understand what P/Invoke is?
I ask because it is of no use to do what you need.
You can do it by creating a simple COM server in
.NET, and loading that via the GetInterfaceObject
method of AcadApplication. Once the COM server
is loaded, it can then load any assemblies using
the Assembly.Load method. Or, you can just make
the main application that you need to load into
AutoCAD a COM server as well. If you do that, and
use IExtensionApplication, the Initialize() member
will still be called.
I need to load .NET DLL into running ACAD application namespace, but externally - out of another process (Startup module, source excerpt below). How possibly can I get it working?
Startup module (that fires ACAD up) references following libs found in GAC:
- Autodesk.AutoCAD.Interop.Common.dll
Imports Autodesk.AutoCAD.Interop
''' Startup module that fires up ACAD
Module Startup
Sub Main()
''' Start ACAD the easy way... No error checking...
Dim oACAD As Autodesk.AutoCAD.Interop.AcadApplication
oACAD = New Autodesk.AutoCAD.Interop.AcadApplication
''' >>> I simply don't want to load assembly via Lisp here.
''' >>> I've been thinking of using P/Invoke, still don't know what set of
''' >>> acad.exe functions is responsible for netload-ing an assembly.
''' >>> Using a bit more managed approach is even more welcome šŸ™‚
"(command " + Chr(34) + _
"NETLOAD" + Chr(34) + " " + Chr(34) + _
End Sub
End Module
Thanks for any suggestion on that matter.
Maksim Sestic
Message 4 of 10
Tony,
I'm trying with COM server and GetInterfaceObject
as you suggested, but I still can't make it work. Here's what I do
(presumably wrong):
1) COM server component named "LoaderServer" -
consists of a public class LoaderClass with Initialize() method that actually
loads .NET assembly named "DotNet.dll":
Imports
size=2> System.Reflection
<ComClass(LoaderClass.ClassId,
LoaderClass.InterfaceId, LoaderClass.EventsId)> _
Public
size=2>
Class
LoaderClass
size=2>Region
"COM GUIDs"
Public
Const
size=2> ClassId
As
String =
"5B5EBDA2-7A4E-45F8-9CA1-CE61435197CA"
Public
Const
size=2> InterfaceId
As
String =
"A3747BA4-DC24-4239-BF8C-7005272AA365"
Public
Const
size=2> EventsId
As
String =
"A9EB5F72-B513-4EE3-9A0E-5BBA2CB29BCB"
size=2>End
size=2>Region
Public
size=2>
Sub
color=#0000ff size=2>New
MyBase
.New()
End
Sub
Public
size=2>
Sub
Initialize()
[Assembly].Load("D:\Test\DotNet.dll")
End
Sub
End
Class
2) There is also a Startup application
called "Startup.exe" that fires ACAD up and initializes COM server via
GetInterfaceObject() call:
size=2>Imports
size=2>Module
Startup
color=#0000ff size=2>Sub
Main()
color=#0000ff>
size=2>Dim
oACAD
size=2>As
size=2>oACAD = New
size=2>
size=2>
color=#0000ff>
size=2>Dim
o
size=2>As
size=2>Object
face="Courier New">
color=#000000>   o =
oACAD.Application.GetInterfaceObject("LoaderServer.LoaderClass")
face="Courier New" size=2>
face="Courier New">  End
size=2>Sub
size=2>End
size=2>Module
Now, everything runs OK (no errors reported) but
DotNet.dll assembly doesn't get loaded into ACAD.
Maksim Sestic
size=2>
Sorry, my previous
is?
You can do it
GetInterfaceObject
is
the Assembly.Load
load into
use
will still be
called.
face=Verdana size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
href="http://www.acadxtabs.com">
size=2>http://www.acadxtabs.com
size=2>"Maksim Sestic" <
face=Verdana size=2>info@geoinova.com
wrote in message
face=Verdana size=2>news:4963788@discussion.autodesk.com
face=Verdana size=2>...
Startup module
Imports
Module Startup
  Sub Main()
    Dim oACAD
    oACAD = New
here.
assembly.
+ _
_
  End
Sub
End Module
matter.
Maksim Sestic
Message 5 of 10
Assembly.Load() does not take a filename. Please look
at the docs.
You need to reference the assembly that you're going to
load, from the COM server assembly that loads it, and
then pass the Display name of the assembly to Load().
Look at the properties of the referenced assembly to
find its display name.
"Maksim Sestic" wrote in message news:4966241@discussion.autodesk.com...
Tony,
I'm trying with COM server and GetInterfaceObject as you suggested, but I still can't make it work. Here's what I do (presumably wrong):
1) COM server component named "LoaderServer" - consists of a public class LoaderClass with Initialize() method that actually loads .NET assembly named "DotNet.dll":
Imports System.Reflection
_
Public Class LoaderClass
#Region "COM GUIDs"
Public Const ClassId As String = "5B5EBDA2-7A4E-45F8-9CA1-CE61435197CA"
Public Const InterfaceId As String = "A3747BA4-DC24-4239-BF8C-7005272AA365"
Public Const EventsId As String = "A9EB5F72-B513-4EE3-9A0E-5BBA2CB29BCB"
#End Region
Public Sub New()
MyBase.New()
End Sub
Public Sub Initialize()
End Sub
End Class
2) There is also a Startup application called "Startup.exe" that fires ACAD up and initializes COM server via GetInterfaceObject() call:
Module Startup
Sub Main()
Dim o As Object
o = oACAD.Application.GetInterfaceObject("LoaderServer.LoaderClass")
End Sub
End Module
Now, everything runs OK (no errors reported) but DotNet.dll assembly doesn't get loaded into ACAD.
Maksim Sestic
"Tony Tanzillo" wrote in message news:4963921@discussion.autodesk.com...
Module Startup
Sub Main()
End Sub
End Module
Maksim Sestic
Message 6 of 10
Hi Tony,
I just did what you've suggested and still
nothing happens (assembly doesn't get loaded into ACAD). I suspect that
Initialize() part of COM server never gets executed, as it would certainly
return either success or an error. Here's the code:
loads .NET assembly named "DotNet". I additionally referenced an
assembly file "DotNet.dll", as per your suggestion, and changed parameter of
[Assembly].Load method to assembly display name:
Imports
Public
size=2>
Class
LoaderClass
size=2>Region
"COM GUIDs"
Public
Const
size=2> ClassId
As
String =
Public
Const
size=2> InterfaceId
As
String =
Public
Const
size=2> EventsId
As
String =
size=2>End
size=2>Region
Public
size=2>
Sub
MyBase
.New()
End
Sub
Public
size=2>
Sub
Initialize()
[Assembly].Load("DotNet")
End
Sub
End
Class
size=2>Imports
size=2>Module
Startup
Main()
color=#0000ff>
size=2>Dim
oACAD
size=2>As
size=2>oACAD = New
size=2>
size=2>
color=#0000ff>
size=2>Dim
o
size=2>As
size=2>Object
face="Courier New">
color=#000000>   o =
size=2>Sub
size=2>End
size=2>Module
Maksim Sestic
Assembly.Load()
at the docs.
You need to
Load().
find its
display name.
wrote in message
face=Verdana size=2>news:4966241@discussion.autodesk.com
Tony,
Imports
System.Reflection
Public Class
LoaderClass
#Region "COM GUIDs"
  Public Const
  Public
#End
Region
Public Sub New()
  MyBase.New()
End
Sub
End Sub
End
Class
call:
Module
Startup
  Sub Main()
    Dim oACAD As
    oACAD = New
    Dim o
As Object
    o =
End Sub
End Module
ACAD.
Maksim
Sestic
"Tony Tanzillo" <
href="mailto:tony.tanzillo@U_KNOW_WHERE.com">
size=2>tony.tanzillo@U_KNOW_WHERE.com
wrote in message
face=Verdana size=2>news:4963921@discussion.autodesk.com
much.
I ask because
server in
method of
assemblies using
make
member
href="http://www.caddzone.com">
wrote in message
Startup module
Imports
Module Startup
  Sub Main()
    Dim oACAD
    oACAD = New
here.
assembly.
+ _
_
  End
Sub
End Module
matter.
Maksim Sestic
Message 7 of 10
If you suspect your Initialize() method is not being
called, then why don't you just run it in the debugger
or place a call to Editor.WriteMessage() in it, to find out?
"Maksim Sestic" wrote in message news:4966390@discussion.autodesk.com...
Hi Tony,
I just did what you've suggested and still nothing happens (assembly doesn't get loaded into ACAD). I suspect that Initialize() part of COM server never gets executed, as it would certainly return either success or an error. Here's the code:
1) COM server component named "LoaderServer" - consists of a public class LoaderClass with Initialize() method that actually loads .NET assembly named "DotNet". I additionally referenced an assembly file "DotNet.dll", as per your suggestion, and changed parameter of [Assembly].Load method to assembly display name:
_
#Region "COM GUIDs"
#End Region
Public Sub New()
MyBase.New()
End Sub
End Sub
End Class
Module Startup
Sub Main()
Dim o As Object
End Sub
End Module
Maksim Sestic
"Tony Tanzillo" wrote in message news:4966307@discussion.autodesk.com...
at the docs.
Tony,
_
#Region "COM GUIDs"
#End Region
Public Sub New()
MyBase.New()
End Sub
End Sub
End Class
Module Startup
Sub Main()
Dim o As Object
End Sub
End Module
Maksim Sestic
Module Startup
Sub Main()
End Sub
End Module
Maksim Sestic
Message 8 of 10
Sorry, I don't follow you. If you suspect that, why don't you
just run it in the debugger and find out for sure?
Message 9 of 10
size=2>Tony,
I'm sorry for not being precise - it definately
never executes COM server's Initialize() sub. On the other hand,
[Assembly].Load GETS executed within Sub New() of called COM's class. Alas,
referenced assembly still doesn't get loaded into ACAD (?)... and NO errors
were generated.
Maksim Sestic
"Maksim Sestic"
wrote
 >> I suspect that Initialize() part of COM server never
gets executed
you
Message 10 of 10
How do you know the assembly doesn't get loaded?
Have you tried creating an instance of a class from
the loaded assembly, in the loading COM server?
Define a simple class in the assembly that's loaded
by the COM server, then rather than explicitly loading
the assembly, simply create an instance of the class
from the COM server.
"Maksim Sestic" wrote in message news:4967312@discussion.autodesk.com...
Tony,
I'm sorry for not being precise - it definately never executes COM server's Initialize() sub. On the other hand, [Assembly].Load GETS executed within Sub New() of called COM's class. Alas, referenced assembly still doesn't get loaded into ACAD (?)... and NO errors were generated.
Maksim Sestic
"Tony Tanzillo" wrote in message news:4966574@discussion.autodesk.com...
ā€Boost
