.NET
Extend an Arc?
3 REPLIES 3
mindofcat
1035 Views, 3 Replies
Extend an Arc?
Hi All,
I'd like to express my appreciation for all the help I've gotten on this forum since I started this journey of converting existing VBA code into VB.NET.
I am almost done with my project, but I just encountered another problem, which has me really stumped...
I have an arc and a line, and I'd like to extend the endpoint of the arc so that it meets the startpoint of the line (image attached in this post). I've tried every which way I could think of, and the results are never what I wish to accomplish.
I searched this forum, and found a likely solution where the CircularArc3D object is being utilized, but unfortunately, this solution utilizes the Curve object's IntersectWith method, and this method crashes my code on a 32-bit system running AutoCAD 2010.
In my code, I also tried arc.EndPoint=line.StartPoint but when I execute, I get a NotImplementedException error in AutoCAD 2010.
Any pointers or suggestions?
Many thanks in advance...
3 REPLIES 3
R.Gerritsen4967
in reply to: mindofcat
Maybe this is of some help?
how to fillet line and arc?
mindofcat
in reply to: R.Gerritsen4967
Thanks for the reply. But I've already been through that post before, and realized it wouldn't solve my problems; I'm not using command line to do my fillet.
However, you just gave me an insight as to what I can try; I can see if filleting will solve this problem. Lemme give it a try...
mindofcat
Problem solved. I tried fillet, and it created the necessary arc to replace the one I needed to extend.
Thanks for the fillet insight...
”Boost
