.NET
extablishing a COM Interface from a .Net dll using 2006
2 REPLIES 2
226 Views, 2 Replies
I would like to extablish a COM interface to AutoCAD 2006 using a .Net dll.
I am able to obtain an system.__ComObject using the following code (this is a class that is created from within my .net dll)
I recieve an exception when I try to reference the active document via this interface
Imports Autodesk.AutoCAD.Interop
Imports AcadCOMintf = Autodesk.AutoCAD.ApplicationServices.Application
Public Enum eDevType
FullScalePDF = 1
FullScaleXerox = 2
End Enum
Public Class ComPlotSetup
Public Shared oAcadCOMApp As Autodesk.AutoCAD.Interop.AcadApplication = CType(AcadCOMintf.AcadApplication, AcadApplication)
Public Sub New(ByVal oPresentFormatInfo As PresentFormat, ByVal DeviceType As eDevType)
Try
Dim oacadCOMDoc As Autodesk.AutoCAD.Interop.AcadDocument
oacadCOMDoc = oAcadCOMApp.DocumentManager.MdiActiveDocument
oacadCOMDoc = oAcadCOMApp.Preferences
Catch
End Try
End Sub
End Class
2 REPLIES 2
Scratch this line, It is an anomoly of "Cut and Paste"
Also, is there any way to get the COM based application object from an
Autodesk.AutoCAD.ApplicationServices.Document object
Please tell me if I am grossly misinformed and out to lunch. I am about ready to take my ball and go home.
I guess that I am still playing ball. this works.
FullScalePDF = 1
FullScaleXerox = 2
End Enum
Try
Dim oAcadCOMDoc As Autodesk.AutoCAD.Interop.AcadDocument
oAcadCOMDoc = oAcadCOMApp.ActiveDocument
MsgBox(oAcadCOMDoc.Name)
Catch
End Try
End Sub
End Class
”Boost
