The managed interop assemblies are not remotable,
which means that you cannot create or manipulate
objects from those assemblies, from another process.
Your only option is to create a remotable layer
using COM, that is loaded into the host process
(AutoCAD or Revit), and have it manipulate the
non-remotable parts.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5388749@discussion.autodesk.com...
Hi all,
I have a COM based application that needs to access the AutoCAD and Revit apis. With AutoCAD, I could use the ActiveX interface, but this is not available for Revit. I am wondering if there is a way of exposing the .NET AutoCAD / Revit api to my COM application?
Thanks for any help.
Patrick
