I want to export .dwg file to .dwfx using .net api, can any one help me in solving this issue.
Solved by djonio. Go to Solution.
Within your plot routine do something like this:
PlotSettings ps_base = (PlotSettings)t.GetObject(ObjectId_of_Layout, OpenMode.ForWrite);
PlotSettingsValidator psv = Autodesk.AutoCAD.DatabaseServices.PlotSettingsValidator.Current;
psv.SetPlotConfigurationName(ps_base, "DWFx ePlot (XPS Compatible).pc3", null);
r,
dennis
Try code written by Balaji Ram from there
just in case if you have DwgPreView installed
and also change file extension on what you need
