.NET
Export to DGN
3 REPLIES 3
chockalingam
536 Views, 3 Replies
Export to DGN
I want to export a set of drawing to DGN format using autocad 2013.
I tried to export using send command, but i am not able to suppress "Export DGN Settings" dialog box.
Can any one guide me in doing this.
Thanks in advance
regards,
R.Chockalingam
3 REPLIES 3
artc2
in reply to: chockalingam
Are you using the "-DGNEXPORT" command (note the leading '-')?  That's the command version that will run without dialogs.
chockalingam
Hi artc2,
Thanks for your reply
I tried "-DGNEXPORT" but the command is only executing after the whole process completed.
Since its a batch process the send command is not helping me.
Is there any other way to handle this?
regards,
Chockalingam
artc2
Could you have your program write a script file that does all of the exports and then use SendStringToExecute to run the script?  That way it wouldn't matter that it happens after your program returns control to Acad.
”Boost
