Export the selection entity to wmf file ?
I try to export the wmf file  wilth  "Autodesk.AutoCAD.Interop.DLL",I find a trouble
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Interop;
using System.Runtime.InteropServices;
 [CommandMethod("NewExport")]
        static public void NewExplort()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            AcadDocument acadDoc = doc.AcadDocument as AcadDocument;
            string exportFile = null;
            exportFile = "C:\\Temp\\Test1.wmf";
            SelectionSet s1=getVll();
            AcadSelectionSet sset=s1 as AcadSelectionSet;
            //***it is error  the sset  is null,but the s1 is not null
            acadDoc.Export(exportFile, "WMF", sset);
       static public SelectionSet getVll()
            SelectionSet SS = null;
            Database db = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
           // Entity entity = null;
            DBObjectCollection entityCollection = new DBObjectCollection();
            PromptSelectionResult ents = ed.SelectAll();
            if (ents.Status == PromptStatus.OK)
                using (Transaction transcation = db.TransactionManager.StartTransaction())
                     SS = ents.Value;
                     transcation.Commit();
            return SS;
 AcadSelectionSet sset=s1 as AcadSelectionSet; // here  is error  ,the sset is null ,but the s1 is not null?how to modify?
you can try with below code:
ents.Value.GetObjectIds()
            DBObjectCollection objectColletion = getVll();
            //acadDoc.SelectionSets.Item("sset").Delete();
            AcadSelectionSet sset = default(AcadSelectionSet);
            AcadSelectionSet ss = acadDoc.SelectionSets.Add("sset");
           AcadSelectionSet mm = new AcadSelectionSetClass();
            for (int j = 0; j < objectColletion.Count; j++)
              object bb = objectColletion[j] as object;
             ss.AddItems(bb);
              sset.AddItems(bb);
            acadDoc.Export(exportFile, "WMF", ss);
  static public DBObjectCollection getVll()
                    // SS = ents.Value;
                    SelectionSet sss = ents.Value;
                    foreach (ObjectId id in sss.GetObjectIds())
                        entity = transcation.GetObject(id, OpenMode.ForWrite, true) as Entity;
                        if (entity != null)
                            entityCollection.Add(entity);
            return entityCollection;
 it is also  error here!  "object bb = objectColletion[j] as object; ss.AddItems(bb);"?  can you help me? how to modify?
is it must be add  " Autodesk.AutoCAD.Interop"DLL  ?
Norman_Yuan
As you already know that since you need to use COM API's AcadDocument.Export() to export WMF file, you need to build an AcadSelectionSet object.
After you create he AcadSelectionSet object, you have different ways to populate the AcadSelectionSet object.
1. Simply use the COM method AcadSelectionSet.Select()/Selectxxx(). It is very simple if you only need to select all entities.
2. If you like to write a lot of code and try .NET API way to select thinfs in AutoCAD, you can use .NET API's Editor.SelectXXX() method, as you did in your 2 posts. However, you must convert the selected objects in .NET API into correctc CPM API type in order to add them into AcadSelectionSet.
AcadSelectionSet.AddItems() takes an array of AcadEntity object, nothing else. which you did wrong in your 2 posted code snippets. In the first set of code, you tried to use Aitodesk.AutoCAD.EditorInput.SelectionSet as AcadSelectionSet. Naturally, they are not the same thing. In the second try, you tries to add and array of Autodesk.AutoCAD.DatabaseService.DBObject into AcadSelectionSet. Again, DBObject in .NET API is not the samething as COM API's AcadEntity.
Below is the code that worked (I used both COM API AcadSelectionSet.Select() and .NET API's Editor.SelectAll() to populate AcadSelectionSet, just to show how to do things in both way):
using Autodesk.AutoCAD.Interop.Common;
[assembly: CommandClass(typeof(ExportWmf.MyCommands))]
namespace ExportWmf
    public class MyCommands
        private static string wmfFile=@"C:\Temp\MyDrawing";
        [CommandMethod("WmfExport")]
        public static void RunMyCommand()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            AcadSelectionSet ss = null;
            AcadDocument doc = (AcadDocument)dwg.AcadDocument;
            try
                AcadApplication app=Application.AcadApplication as AcadApplication;
                app.ZoomExtents();
                //--Use COM API to select objects
                //ss = GetAcadSelectionSet1(doc);
                //Use .NET API to select objects, and
                //selected objects must to be cast to AcadEntity
                //before populated into AcadSelecctionSet
                ss = GetAcadSelectionSet2(dwg);
                if (System.IO.File.Exists(wmfFile)) System.IO.File.Delete(wmfFile);
                doc.Export(wmfFile, "WMF", ss);
            catch (System.Exception ex)
                ed.WriteMessage("\nCommand \"MyCmd\" failed:");
                ed.WriteMessage("\n{0}\n{1}", ex.Message, ex.StackTrace);
            finally
                ss.Delete();
                Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        private static AcadSelectionSet GetAcadSelectionSet1(AcadDocument doc)
            AcadSelectionSet ss = doc.SelectionSets.Add("WmfSet");
            ss.Select(AcSelect.acSelectionSetAll);
            return ss;
        private static AcadSelectionSet GetAcadSelectionSet2(Document dwg)
            AcadDocument doc = dwg.AcadDocument as AcadDocument;
            List<AcadEntity> lst = new List<AcadEntity>();
            PromptSelectionResult res = dwg.Editor.SelectAll();
            if (res.Status == PromptStatus.OK)
                using (Transaction tran = dwg.TransactionManager.StartTransaction())
                    foreach (ObjectId id in res.Value.GetObjectIds())
                        Entity ent = (Entity)tran.GetObject(id, OpenMode.ForRead);
                        lst.Add(ent.AcadObject as AcadEntity);
                    tran.Commit();
                ss.AddItems(lst.ToArray());
                return ss;
            else
                return null;
 HTH
Norman Yuan
Drive CAD With Code
Hi norman.yuan ,
Thank you ! I get it,I love U
