Bom dia,
Gostaria de exportar o (cota alinhada) e (dimensão girado), que informação para se destacar?
propriedades
Guia Texto
1. Texto Posição X
2. Posição do Texto Y
3. Medição
4. Substituir texto
E estar no mesmo LISP, Texto
propriedades
Guia Geral
cor 151
Guia Texto
conteúdo
do texto Alinhamento X
Texto Alinhamento Y
Alguém pode me ajudar por favor?
Atenciosamente
Sidnei Gomes
Good morning,
I would like to export the (aligned dimension) and (rotated dimension), what information to excel?
properties
Text Guide
1. Text Position X
2. Text Position Y
3. Measurement
4. Override Text
And being in the same LISP, Text
properties
General Guide
color 151
Text Guide
contents
Text Alignment X
Text Alignment Y
Can someone help me please?
Best Regards
Sydney Gomes
Hi Sidnei,
I understand that you want to export said properties to excel file.
I have written a sample code which can be used as boiler plate code to export required properties to CSV ,
which you can open in a excel sheet.
SampleCode:
[CommandMethod("DimensionExport")] public void Test_cmd2() { var doc = Application.DocumentManager.MdiActiveDocument; var db = doc.Database; var ed = doc.Editor; var dimensionId = ObjectId.Null; var psr = ed.GetSelection(); if (psr.Status != PromptStatus.OK) return; if (psr.Value.Count == 1) { var selId = psr.Value[0].ObjectId; if (selId.ObjectClass.IsDerivedFrom(RXObject.GetClass(typeof(Dimension)))) { dimensionId = selId; } } if (dimensionId == ObjectId.Null) { var peo = new PromptEntityOptions("\nSelect a Dimension Entity"); peo.SetRejectMessage("\nEntity is not a Dimension Entity."); peo.AddAllowedClass(typeof(Dimension), false); var per = ed.GetEntity(peo); if (per.Status != PromptStatus.OK) return; dimensionId = per.ObjectId; } var psfo = new PromptSaveFileOptions("Export Data"); psfo.Filter = "Comma Delimited (*.csv)|*.csv"; var pr = ed.GetFileNameForSave(psfo); if (pr.Status != PromptStatus.OK) return; var csv = pr.StringResult; // Our main StringBuilder to get the overall CSV contents var sb = new StringBuilder(); using (var t = db.TransactionManager.StartTransaction()) { AlignedDimension aDim = t.GetObject(dimensionId, OpenMode.ForRead) as AlignedDimension; // var sb2 = new StringBuilder(); var colortext = aDim.Color.ToString(); sb.Append(colortext); sb.AppendLine(); var dimStyleName = aDim.DimensionStyleName; sb.Append(dimStyleName); sb.AppendLine(); var dimText = aDim.DimensionText; sb.Append(dimText); sb.AppendLine(); /*You can append required properties to the string builder and export those to CSV stream*/ // // // t.Commit(); } var contents = sb.ToString(); if (!String.IsNullOrWhiteSpace(contents)) { try { // Write the contents to the selected CSV file using (var sw = new StreamWriter(csv, false, Encoding.UTF8)) { sw.WriteLine(sb.ToString()); } } catch (System.IO.IOException) { // We might have an exception, if the CSV is open in // Excel, for instance... could also show a messagebox ed.WriteMessage("\nUnable to write to file."); } } }
Posted by: Madhukar Moogala
Contact information: madhukar.moogala@autodesk.com.
Hi Sidnei,
I understand that you want to export said properties to excel file.<br>
I have written a sample code which can be used as boiler plate code to export required properties to CSV ,<br>
Sample Code :
Madhukar
