.NET
Export pdf from VB.net
13 REPLIES 13
Message 1 of 14
7643 Views, 13 Replies
Hi
  I'm trying to make an application that would take a drawing(dwg) and convert it to pdf.  Since I can do it directly in autocad 2013, i presume that there should be a function in the API, that i could use to do the same.  So far, i tried with AcadDocument.export(filename, FileExtension, AcadSelectionSet) with no luck. I cannot put PDF as a valid file extension.
Here's my code
Public sub SaveToPDF(ByVal psfilename As String)
Dim oAutocad As AutoCAD.AcadApplication = New AutoCAD.AcadApplication()
Dim oAcadDoc As AutoCAD.AcadDocument = oAutocad.Documents.Open(psfilename, True)
Dim sFolder As String = psfilename.Substring(0, psfilename.LastIndexOf("\") + 1)
Dim sFilename As String = psfilename.Substring(psfilename.LastIndexOf("\") + 1, (psfilename.Length - psfilename.LastIndexOf("\")) - (psfilename.Length - psfilename.LastIndexOf(".") + 1))
Dim oSS As AcadSelectionSet = Nothing
Try  oSS = oAutocad.ActiveDocument.SelectionSets.Add("MySet")
     oSS.Select(AcSelect.acSelectionSetAll)
     oAutocad.ActiveDocument.Export(sFolder & sFilename & ".pdf", ".pdf", oSS)
     oSS.Delete() Catch ex As Exception  success = False  oSS.Delete()
     oSS = Nothing
End Try
For Each Doc In oAutocad.Documents
  Doc.Close(False)
Next
oAutocad.Quit()
oAutocad = Nothing
end sub
Does anyone have an idea?
13 REPLIES 13
Message 2 of 14
Alfred.NESWADBA
you will have to go through the plot-functionality using the "DWG to PDF.pc3"
That makes also more sense for setting the page-size you like to have as result.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 14
Hallex
See if this helps
    Imports System.IO
    <CommandMethod("pdfing")> _
    Public Sub TestPDF()
        SaveToPDF("C:\Test\blah.dwg")
    End Sub
    Public Sub SaveToPDF(ByVal psfilename As String)
        Dim oAutocad As AcadApplication = New AcadApplication
        oAutocad.Visible = True
        oAutocad.WindowState = AcWindowState.acMax
        Dim success As Boolean = False
        Dim oAcadDoc As AcadDocument = oAutocad.Documents.Open(psfilename, False, "")
        'Dim sFolder As String = Path.GetDirectoryName(psfilename) 'psfilename.Substring(0, psfilename.LastIndexOf("\") + 1)
        'Dim sFilename As String = Path.GetFileNameWithoutExtension(psfilename) 'psfilename.Substring(psfilename.LastIndexOf("\") + 1, (psfilename.Length - psfilename.LastIndexOf("\")) - (psfilename.Length - psfilename.LastIndexOf(".") + 1))
        Try
            Dim ftype(0) As Short
            ftype(0) = 410
            Dim fdata(0) As Object
            fdata(0) = "Model"
            oAutocad.ZoomExtents()
            oSS = oAcadDoc.SelectionSets.Add("MySet")
            oSS.Select(AcSelect.acSelectionSetAll, Nothing, Nothing, ftype, fdata)
            CreatePDF(oAcadDoc)
            If oAcadDoc.Saved Then
                oAcadDoc.Close(False)
            oAcadDoc = Nothing
            oAutocad.Quit()
            oAutocad = Nothing
            success = True
            MsgBox(ex.Message + vbLf + ex.StackTrace)
            success = False
        Finally
            MsgBox(vbLf + "Program ended up with result of: " + success.ToString)
        End Try
    End Sub
    Sub CreatePDF(acDoc As AcadDocument) 'by RBell
        Dim PtConfigs As AcadPlotConfigurations
        Dim PlotConfig As AcadPlotConfiguration
        Dim PtObj As AcadPlot
        Dim BackPlot As Object
        'Create a new plot configutrarion with all needed parameters
        PtObj = acDoc.Plot
        PtConfigs = acDoc.PlotConfigurations
        'Add a new plot configuration
        PtConfigs.Add("PDF", False)
        'The plot config you created become active
        PlotConfig = PtConfigs.Item("PDF")
        'Use this method to set the scale
        PlotConfig.StandardScale = AcPlotScale.acScaleToFit
        'Updates the plot
        PlotConfig.RefreshPlotDeviceInfo()
        'Here you specify the pc3 file you want to use
        PlotConfig.ConfigName = "DWG To PDF.pc3"
        'You can select the plot style table here
        PlotConfig.StyleSheet = "acad.ctb"
        'Specifies whether or not to plot using the plot styles
        PlotConfig.PlotWithPlotStyles = True
        'If you are going to create pdf files in a batch mode,
        'I would recommend to turn off the BACKGROUNDPLOT system variable,
        'so autocad will not continue to do anything until finishes
        'the pdf creation
        BackPlot = acDoc.GetVariable("BACKGROUNDPLOT")
        acDoc.SetVariable("BACKGROUNDPLOT", 0)
        'Updates the plot
        ''Acad.ActiveDocument.ActiveLayout.CopyFrom(plotconfig)
        'Now you can use the PlotTofile method
        If PtObj.PlotToFile(Replace(acDoc.FullName, "dwg", "pdf"), PlotConfig.ConfigName) Then
            acDoc.Utility.Prompt(vbLf + "PDF Was Created")
        Else
            acDoc.Utility.Prompt(vbLf + "PDF Creation Unsuccessful")
        'If you wish you can delete th plot configuration you created
        'programmatically, and set the 'BACKGROUNDPLOT' system variable
        'to its original status.
        PtConfigs.Item("PDF").Delete()
        PlotConfig = Nothing
        acDoc.SetVariable("BACKGROUNDPLOT", BackPlot)
    End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 4 of 14
Thanks guys
  I've been able to convert my drawing in a pdf.  The next step is turning my application into a windows service.  i'm not able to start autocad.  I see the process comming up in task manager but the next line ain't executed.  Is there a way to open autocad in a windows service application?
Andre
Message 5 of 14
DudiPeer
ho andre
there is a trick you can do if you still interesets
dudi
Message 6 of 14
btmsoftware
in reply to: DudiPeer
Dudi,
I'd be interested inthis trick...
Message 7 of 14
in reply to: btmsoftware
Hi Hallex.
Looks great. Is there any ways to export to pdf without open the drawing (using ReadDWGfile(...
) method.
Message 8 of 14
kellyE3ZK8
Hi andre,
I still have the same problem of converting the dwg file to pdf.
Could you please kindly show your code?
Thank you very much!
Tags (1)
Message 9 of 14
kellyE3ZK8
in reply to: kellyE3ZK8
Oh my mistake...
I found my pdf files
They were in "C:\Users\Administrator\AppData\Local\Temp"
Thank Hallex and RBell!
Message 10 of 14
Dudi,
Any chance you could share this trick with us?
Message 11 of 14
kellyE3ZK8
I just copy the Hallex's code. It works but I thought it could not work before because I cannot find my pdf files.
But Hallex's code actually works!
The pdf files are hidden in somewhere in the computer. You may check it out with "CreatePDF" and see his code the line of  "If PtObj.PlotToFile(Replace(acDoc.FullName, "dwg", "pdf"), PlotConfig.ConfigName) Then".
The variable of "FullName" is the path of the pdf files saved.
Message 12 of 14
btmsoftware
I think the tip was about using AutoCAD as a Windows service, not the PDF generation.
If anybody has a trip to use AutoCAD as a windows service, please, share
Message 13 of 14
Hi !
this may be the right way for my problem. i want to use the exportpdf-function of autocad via vb.net.
but what means the .....
  Imports System.IO
    End Sub
 so current i did know how to find the defintion of
  • AcadPlotConfigurations
  • AcPlotScale
regards Jan
Message 14 of 14
nghnbstn
in reply to: jan_tappenbeck
Hello ,Add application from the project tab then select AutoCad.
”Boost
