.NET
Member
0 Kudos
Post 1 of 7
Export pdf from VB.net
2467 Views, 6 Replies
05-24-2012 06:32 PM
Hi
  I'm trying to make an application that would take a drawing(dwg) and convert it to pdf.  Since I can do it directly in autocad 2013, i presume that there should be a function in the API, that i could use to do the same.  So far, i tried with AcadDocument.export(filename, FileExtension, AcadSelectionSet) with no luck. I cannot put PDF as a valid file extension.
Here's my code
Public sub SaveToPDF(ByVal psfilename As String)
Dim oAutocad As AutoCAD.AcadApplication = New AutoCAD.AcadApplication()
Dim oAcadDoc As AutoCAD.AcadDocument = oAutocad.Documents.Open(psfilename, True)
Dim sFolder As String = psfilename.Substring(0, psfilename.LastIndexOf("\") + 1)
Dim sFilename As String = psfilename.Substring(psfilename.LastIndexOf("\") + 1, (psfilename.Length - psfilename.LastIndexOf("\")) - (psfilename.Length - psfilename.LastIndexOf(".") + 1))
Dim oSS As AcadSelectionSet = Nothing
Try  oSS = oAutocad.ActiveDocument.SelectionSets.Add("MySet")
     oSS.Select(AcSelect.acSelectionSetAll)
     oAutocad.ActiveDocument.Export(sFolder & sFilename & ".pdf", ".pdf", oSS)
     oSS.Delete() Catch ex As Exception  success = False  oSS.Delete()
     oSS = Nothing
End Try
For Each Doc In oAutocad.Documents
  Doc.Close(False)
Next
oAutocad.Quit()
oAutocad = Nothing
end sub
Does anyone have an idea?
1,218 Kudos
Post 2 of 7
Re: Export pdf from VB.net
05-24-2012 11:32 PM in reply to: andre.fortin
you will have to go through the plot-functionality using the "DWG to PDF.pc3"
That makes also more sense for setting the page-size you like to have as result.
- alfred -
Alfred NESWADBA
171 Kudos
Post 3 of 7
05-25-2012 04:55 AM in reply to: andre.fortin
See if this helps
    Imports System.IO
    <CommandMethod("pdfing")> _
    Public Sub TestPDF()
        SaveToPDF("C:\Test\blah.dwg")
    End Sub
    Public Sub SaveToPDF(ByVal psfilename As String)
        Dim oAutocad As AcadApplication = New AcadApplication
        oAutocad.Visible = True
        oAutocad.WindowState = AcWindowState.acMax
        Dim success As Boolean = False
        Dim oAcadDoc As AcadDocument = oAutocad.Documents.Open(psfilename, False, "")
        'Dim sFolder As String = Path.GetDirectoryName(psfilename) 'psfilename.Substring(0, psfilename.LastIndexOf("\") + 1)
        'Dim sFilename As String = Path.GetFileNameWithoutExtension(psfilename) 'psfilename.Substring(psfilename.LastIndexOf("\") + 1, (psfilename.Length - psfilename.LastIndexOf("\")) - (psfilename.Length - psfilename.LastIndexOf(".") + 1))
        Try
            Dim ftype(0) As Short
            ftype(0) = 410
            Dim fdata(0) As Object
            fdata(0) = "Model"
            oAutocad.ZoomExtents()
            oSS = oAcadDoc.SelectionSets.Add("MySet")
            oSS.Select(AcSelect.acSelectionSetAll, Nothing, Nothing, ftype, fdata)
            CreatePDF(oAcadDoc)
            If oAcadDoc.Saved Then
                oAcadDoc.Close(False)
            End If
            oAcadDoc = Nothing
            oAutocad.Quit()
            oAutocad = Nothing
            success = True
            MsgBox(ex.Message + vbLf + ex.StackTrace)
            success = False
        Finally
            MsgBox(vbLf + "Program ended up with result of: " + success.ToString)
        End Try
    End Sub
    Sub CreatePDF(acDoc As AcadDocument) 'by RBell
        Dim PtConfigs As AcadPlotConfigurations
        Dim PlotConfig As AcadPlotConfiguration
        Dim PtObj As AcadPlot
        Dim BackPlot As Object
        'Create a new plot configutrarion with all needed parameters
        PtObj = acDoc.Plot
        PtConfigs = acDoc.PlotConfigurations
        'Add a new plot configuration
        PtConfigs.Add("PDF", False)
        'The plot config you created become active
        PlotConfig = PtConfigs.Item("PDF")
        'Use this method to set the scale
        PlotConfig.StandardScale = AcPlotScale.acScaleToFit
        'Updates the plot
        PlotConfig.RefreshPlotDeviceInfo()
        'Here you specify the pc3 file you want to use
        PlotConfig.ConfigName = "DWG To PDF.pc3"
        'You can select the plot style table here
        PlotConfig.StyleSheet = "acad.ctb"
        'Specifies whether or not to plot using the plot styles
        PlotConfig.PlotWithPlotStyles = True
        'If you are going to create pdf files in a batch mode,
        'I would recommend to turn off the BACKGROUNDPLOT system variable,
        'so autocad will not continue to do anything until finishes
        'the pdf creation
        BackPlot = acDoc.GetVariable("BACKGROUNDPLOT")
        acDoc.SetVariable("BACKGROUNDPLOT", 0)
        'Updates the plot
        ''Acad.ActiveDocument.ActiveLayout.CopyFrom(plotconfig)
        'Now you can use the PlotTofile method
        If PtObj.PlotToFile(Replace(acDoc.FullName, "dwg", "pdf"), PlotConfig.ConfigName) Then
            acDoc.Utility.Prompt(vbLf + "PDF Was Created")
        Else
            acDoc.Utility.Prompt(vbLf + "PDF Creation Unsuccessful")
        End If
        'If you wish you can delete th plot configuration you created
        'programmatically, and set the 'BACKGROUNDPLOT' system variable
        'to its original status.
        PtConfigs.Item("PDF").Delete()
        PlotConfig = Nothing
        acDoc.SetVariable("BACKGROUNDPLOT", BackPlot)
    End Sub
~'J'~
Member
0 Kudos
Post 4 of 7
05-25-2012 10:29 AM in reply to: andre.fortin
Thanks guys
  I've been able to convert my drawing in a pdf.  The next step is turning my application into a windows service.  i'm not able to start autocad.  I see the process comming up in task manager but the next line ain't executed.  Is there a way to open autocad in a windows service application?
Andre
New Member
0 Kudos
Post 5 of 7
11-21-2013 05:17 AM in reply to: andre.fortin
ho andre
there is a trick you can do if you still interesets
dudi
Active Contributor
0 Kudos
Post 6 of 7
11-23-2013 12:53 AM in reply to: DudiPeer
Dudi,
I'd be interested inthis trick...
Active Contributor
2 Kudos
Post 7 of 7
11-24-2013 05:11 PM in reply to: btmsoftware
Hi Hallex.
Looks great. Is there any ways to export to pdf without open the drawing (using ReadDWGfile(...
) method.
