.NET
mathewk
Message 1 of 4 (848 Views)
Exploding Blocks
848 Views, 3 Replies
09-01-2010 01:23 PM
Below is my existing code.  ss is a selection set which has been populated by SelectAll which limits the selection to blocks and tables.
The For Next loop iterates through this collection and attempts to explode each object (ent.Explode(acDBObjColl)
).  They do not actually explode and the code does not generate any errors.  I can replace the block selection with polylines which do explode.  This leads me to believe my code is correct in that it's exploding objects.  It just doesn't seem to work with blocks.
How might I get this code to explode blocks?
Thanks.
        'explode them
        If SelectResult.Status = PromptStatus.OK Then
            ss = SelectResult.Value
            count = ss.Count
            For i = 1 To count
                id = ss.Item(count - 1).ObjectId
                ent = id.GetObject(OpenMode.ForWrite, True, True)
                Dim acDBObjColl As DBObjectCollection = New DBObjectCollection()
                For Each acEnt As Entity In acDBObjColl
                    btrModelSpace.AppendEntity(acEnt)
                    trans.AddNewlyCreatedDBObject(acEnt, True)
                Next
                trans.Commit()
            Next
            ss.Dispose()
        End If
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
You need to erase the original object
 and you say blocks do you mean BlockReferences or show full code
Valued Mentor
Jeffrey_H
Message 2 of 4 (850 Views)
Re: Exploding Blocks
09-01-2010 01:41 PM in reply to: mathewk
You can also find your answers @ TheSwamp
mathewk
Message 3 of 4 (840 Views)
09-01-2010 02:21 PM in reply to: Jeffrey_H
Correct, I mean BlockReferences.  So after I erase the original object, all the objects from the explode will just appear?
Matt Kolberg
mathewk
Message 4 of 4 (832 Views)
09-01-2010 04:14 PM in reply to: Jeffrey_H
Thanks.  I got it working.
Matt Kolberg
