.NET
Explode Scaled Block Programmatically
0 REPLIES 0
Message 1 of 1
zhaoxin1224
270 Views, 0 Replies
I have a separate exe written in C#.
It opens a DWG file, finds blocks and explodes them.
I came across an issue when a block(objBlock) is scaled (XScaleFactor or YScaleFactor is not 1) and do objBlock.Explode(), it threw an error (Invalid input).
If I set the block's XScaleFactor and YScaleFactor to 1 before objBlock.Explode(), it has no problem.
But the result is not the same size as the original scaled block.
Is there a way I can explode a scaled block and keeps its scaled size?
Xin
0 REPLIES 0
”Boost
