.NET
Explode Dimension
5 REPLIES 5
1232 Views, 5 Replies
Explode Dimension
I'm looking for a way to explode a dimension. I've tried using the Explode() method, but it just results in an eInvalidInput error. Is there a way to explode a dimension into objects?
The reason for this is that I'm using Autocad Architecture and I'm auto-labeling and dimensioning some items I am inserting into the drawing, however the 2d elevation drawing tool in Architecture automatically ignores text and dimensions, so I need a way to explode these into lines so they will show up in the 2d elevation drawings.
5 REPLIES 5
So, am I to assume that this is not possible?
calvindale
You could use the BURST command to explode dimenisons. BURST can be executed via the SendCommand() method.
For example to explode everything including dimensions, the following snippet works:
[CommandMethod("XA")]
public static void ExplodeAllDrawingEntitiesViaSendCommand() {
    "DRAWORDERCTL{0}0{0}BURST{0}ALL{0}{0}EXPLODE{0}ALL{0}{0}DRAWORDERCTL{0}3{0}".SendCommand("\n");
 where SendCommand is exposed as an extension method
    public static void SendCommand(this string commandFormat, params object[] args) {
        var acadApplication = a.Application.AcadApplication as AcadApplication;
        acadApplication.ActiveDocument.SendCommand(string.Format(commandFormat, args));
 The downside with this approach is that it requires interop with COM dlls.
Hallex
Not sure about if this work on your end,
I tested on A2010 all is good for me
    <CommandMethod("dex")> _
    Public Sub TestExplode()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        ' Select a dimension
        Dim opts As New PromptEntityOptions(vbLf & "Select a dimension:")
        opts.SetRejectMessage(vbLf & "Must be a dimension...")
        ' opts.AddAllowedClass(GetType(Dimension), False)
        Dim res As PromptEntityResult = ed.GetEntity(opts)
        If res.Status <> PromptStatus.OK Then
            Exit Sub
        End If
        Dim db As Database = doc.Database
        Using trans As Transaction = db.TransactionManager.StartTransaction
            Dim dm As DBObject = trans.GetObject(res.ObjectId, OpenMode.ForRead)
            ed.WriteMessage(vbLf + "{0}", dm.GetType().Name)
            Dim m_dim As Dimension = TryCast(dm, Dimension)
            m_dim.UpgradeOpen()
            Dim objs As DBObjectCollection = New DBObjectCollection
            m_dim.Explode(objs)
            Dim btr As BlockTableRecord = trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
            'add exploded object to database
            For Each obj As DBObject In objs
                Dim ent As Entity = TryCast(obj, Entity)
                If TypeOf ent Is MText Then
                    Dim mtx As MText = TryCast(ent, MText)
                    'change textstyle here
                    mtx.TextHeight = mtx.TextHeight * 0.5
                End If
                btr.AppendEntity(ent)
                trans.AddNewlyCreatedDBObject(ent, True)
                ed.WriteMessage(vbLf + "{0}", obj.GetType().Name)
            Next
            'erase dimension
            m_dim.Erase()
            trans.Commit()
        End Using
    End Sub
~'J'~
whamlin
EXPLMODE = 0
mszanto
The eInvalidInput error occurs on newly created dimensions. The following worked for me.
1. Make sure the dimension has been appended and added (AppendEntity and AddNewlyCreatedDBObject) and has a valid ObjectId.
2. Execute
Transaction.TransactionManager.QueueForGraphicsFlush().
3. Explode
”Boost
