.NET
excludeFromOsnapCalculation
5 REPLIES 5
markodjurovic
467 Views, 5 Replies
If anybody knows pls help. In ObjectARX exists method excludeFromOsnapCalculation of AcEdInputPointMonitor class. Does anybody knows any class and appropiate method in .NET API (for version 2006)?
5 REPLIES 5
in reply to: markodjurovic
I'm afraid not.
I've had to drop down to native ObjectARX for a number of
things (including this one) that are not exposed via .NET.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5238743@discussion.autodesk.com...
I was afraid of that.
Anyway thank you Tony
gooms
I am also looking for the equivalent of the excludeFromOsnapCalculation function. Anybody know if this function is included in the new dotNET API for AutoCAD 2010? If not, any ideas out there on how to accomplish a similar result? Thanks!
No need for excludeFromOsnapCalculation() in AutoCAD 2010.
You can do what that native API does and much more using an OsnapOverrule.
The project at the link below includes three sample overrules, one of which
shows how to use OsnapOverrule to supress object snapping to circles.
http://www.caddzone.com/OverruleSample.zip
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:6174543@discussion.autodesk.com...
result? Thanks!
gooms
First of all thank you so much for your sample code.
I was finally able to do some tests using your examples but I did come across a couple of problems. First is when trying to suppress object snapping to blocks (BlockReference), it seems like object snaps to the block’s sub-entities are still enabled. As far as I can tell only the Insertion Osnap is suppressed. Is there a way to suppress object snapping for the whole block (including its sub-entities)? My second problem is I still can't figure out how to suppress object snapping for a single entity.
Really appreciate your help. Thanks!
”Boost
