.NET
Exception on command db.database.saveas(filename,dwgcurrent.curent)
2 REPLIES 2
AubelecBE
466 Views, 2 Replies
my code :
InfoFichier = New FileInfo(Txt)
 'enregistrement
dwg.Database.SaveAs(Txt, DwgVersion.Current)
'vérification si fichier existe bien !
If InfoFichier.Exists = True Then
    dwg.CloseAndDiscard()
i have buid with framework 3.5.
This code work fine with Autocad v2010 but i have a exception with Autocad v2009. (same .dll)
exception DwgVersion.current
I have try another DwgVersion.AC1014 and other  but it  crash always on the SaveAS.
Can you explain this  ?
Thx
PS : I need to have the same .DLL. (At work, i have computers on Autocad 2009 and v2010). And i dont know how to programm ths VS project for multi buid.)
2 REPLIES 2
arcticad
in reply to: AubelecBE
dwg.Database.SaveAs(strDWGName, True, DwgVersion.Current, _
                                          dwg.Database.SecurityParameters)
(defun botsbuildbots() (botsbuildbots))
AubelecBE
in reply to: arcticad
Thx.
”Boost
