Can't seem to find the answer, but IIRC, you get this when your copy local is set to true. Try that. if not, post the offending code and let see if the smart peeps can figure it out 🙂
HomeBoy Out
Usually see That error if you netload the dll then change it and try to rebuild it without closing down autocad
Will not let you rebuild it if it is being used by autocad
This happens in sharepoint A LOT. Lots of various reasons, but it seems like a majority are caused by out of context use. It would make sense that a conflict between build version and load version would create an error.
HomeBoy Out
