.NET
Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED)
0 REPLIES 0
Message 1 of 1
Luigi71
550 Views, 0 Replies
Hi to all, as per the subject I'm getting this exception running the code below
The code works fine up to the bolded line (mg.Toolbars.Item(i).Visible = True), executing this instruction I get this exception : 'Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED)' (ex2.Message).
Dim mg As AcadMenuGroup
 Try
 mg = Application.MenuGroups.Item(cuiname)
 Catch ex As System.Exception
 Dim mg2 As AcadMenuGroups = CType(Application.MenuGroups, AcadMenuGroups)
 mg2.Load(cuifile)
 mg = Autodesk.AutoCAD.ApplicationServices.Application.MenuGroups.Item(cuiname)
 Dim i As Integer
 Try
  For i = 0 To mg.Toolbars.Count - 1
  Next
  Catch ex2 As System.Exception
  MsgBox(ex2.Message)
 End Try
End Try
The strange thing is that until a short time ago I don't had this problem!!!
Some suggestions or tips?
I'm running the code in Windows7 x64, Visualbasic 2008 Express Edition, Autocad 2010 x64.
See attachment for more informations on this issue.
Thanks to all in advance.
0 REPLIES 0
”Boost
