.NET
EventsWatcher Sample in ObjectsARX 2013
3 REPLIES 3
AloyH
364 Views, 3 Replies
I have tried to build the EventsWatcher Sample project in ObjectARX 2013 (also in 2011) but error message says Namespace 'Windows' and 'Drawings' are not in Namespace 'System' and suggest am I missing a reference. The readme file only says I have to reference two managed dlls. There are four ...Mgd.dll in the inc folder. Which are the once I should reference?.
Thanks for any help.
AloyH
3 REPLIES 3
kdub_nz
in reply to: AloyH
I just built the project from the SDK without issue.
Did you open the  EventsWatcher.csproj file in visual studio ??  .. or one of the .cs files ?
for info, the AutoCAD dlls referenced are
...\ObjectARX 2013\inc\accoremgd.dll
...\ObjectARX 2013\inc\acdbmgd.dll
...\ObjectARX 2013\inc\acmgd.dll
the others you mention are
C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.0\System.Drawing.dll
C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.0\System.Windows.Forms.dll
Regards
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
AloyH
in reply to: AloyH
Thank you very much Kerry. Your info helped a lot. There are eight .Net events and I am trying to find examples of implimenting them. Any location where I can find them?
AloyH
kdub_nz
in reply to: AloyH
@AloyH wrote:
<..>  There are eight .Net events and I am trying to find examples of implimenting them. Any location where I can find them?
AloyH
Depends what they are 🙂
Have you seen
http://adndevblog.typepad.com/autocad/2012/04/dwg-debugger-mgddbg-app-for-autocad-20122013.html
”Boost
