.NET
Distinguished Contributor
13 Kudos
Post 1 of 5
Event Monitor
344 Views, 4 Replies
09-07-2012 03:28 AM
Bit of a long shot here, but does anyone know of an application or piece of code which monitors AutoCAD and reports when events are triggered?
I'm looking to see when events are triggered in relation to each other and wonder if anyone else has attempted anything like this in the past?
Many thanks
Valued Contributor
6 Kudos
Post 2 of 5
Re: Event Monitor
09-07-2012 04:45 AM in reply to: dbrblg
Are you talking about watching events internally to AutoCAD or externally from a systems' standpoint?
13 Kudos
Post 3 of 5
Re: Event Monitor
09-07-2012 05:10 AM in reply to: bjhuffine
Watching events internally to AutoCAD, although if the latter existed i'd have that too :smileywink:
Valued Contributor
6 Kudos
Post 4 of 5
Re: Event Monitor
09-07-2012 06:28 AM in reply to: dbrblg
Cool... I just didn't want to mention anything that doesn't apply.  You can find some things on it here: http://adndevblog.typepad.com/autocad/
After doing a search I found these specifically:
http://adndevblog.typepad.com/autocad/2012/08/managing-events-at-a-per-document-level.html
http://adndevblog.typepad.com/autocad/2012/05/handling-events-in-vbnet.html
(there was more so who knows there may be something more specific to what you're looking for.  Also, I didn't look at these in any great detail so hopefully their accurate).
Here's something I did some time back in a project where I needed to track a few application-level events... specifically window moved and sized events as well as determining whether or not AutoCAD is quiescent before moving on to a specific process.  I've modified it so that you can use it to illustrate in your own project (no command is necessary... just netload and try a few things out in AutoCAD).
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Internal.Reactors;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
[assembly: ExtensionApplication(typeof(AutoCADEvents.CADApplicationExtension))]
namespace AutoCADEvents
    public sealed class CADApplicationExtension : IExtensionApplication
        #region IExtensionApplication Interface Implementation To Register/Deregister Events
        void IExtensionApplication.Initialize()
            ApplicationEventManager appEventMgr = ApplicationEventManager.Instance();
            appEventMgr.ApplicationMainWindowMoved += new ApplicationMainWindowMovedEventHandler(appEventMgr_ApplicationMainWindowMoved);
            appEventMgr.ApplicationMainWindowSized += new ApplicationMainWindowSizedEventHandler(appEventMgr_ApplicationMainWindowSized);
            Application.DocumentManager.DocumentBecameCurrent += new DocumentCollectionEventHandler(DocumentManager_DocumentBecameCurrent);
            Application.DocumentManager.DocumentToBeDeactivated += new DocumentCollectionEventHandler(DocumentManager_DocumentToBeDeactivated);
            Application.DocumentManager.DocumentToBeDestroyed += new DocumentCollectionEventHandler(DocumentManager_DocumentToBeDestroyed);
            Application.DocumentManager.DocumentDestroyed += new DocumentDestroyedEventHandler(DocumentManager_DocumentDestroyed);
            Document activeDoc = Application.DocumentManager.MdiActiveDocument;
            activeDoc.Editor.EnteringQuiescentState += new EventHandler(ed_EnteringQuiescentState);
            activeDoc.Editor.LeavingQuiescentState += new EventHandler(ed_LeavingQuiescentState);
            activeDoc.CommandCancelled += new CommandEventHandler(Document_CommandCancelled);
        void IExtensionApplication.Terminate()
            Application.DocumentManager.DocumentBecameCurrent -= new DocumentCollectionEventHandler(DocumentManager_DocumentBecameCurrent);
            Application.DocumentManager.DocumentToBeDeactivated -= new DocumentCollectionEventHandler(DocumentManager_DocumentToBeDeactivated);
            Application.DocumentManager.DocumentToBeDestroyed -= new DocumentCollectionEventHandler(DocumentManager_DocumentToBeDestroyed);
            Application.DocumentManager.DocumentDestroyed -= new DocumentDestroyedEventHandler(DocumentManager_DocumentDestroyed);
        #endregion
        #region A Couple Window Events
        void appEventMgr_ApplicationMainWindowSized(object sender, EventArgs e)
            try
                Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
                ed.WriteMessage("\nAutoCAD's window size just changed.\n");
            catch { }
        void appEventMgr_ApplicationMainWindowMoved(object sender, EventArgs e)
            try
                ed.WriteMessage("\nAutoCAD's window was just moved.\n");
            catch { }
        #endregion
        #region Some Document Events Used to Determine Application Quiescence In This Example
        void DocumentManager_DocumentBecameCurrent(object sender, DocumentCollectionEventArgs e)
            Editor ed = e.Document.Editor;
            ed.EnteringQuiescentState += new EventHandler(ed_EnteringQuiescentState);
            ed.LeavingQuiescentState += new EventHandler(ed_LeavingQuiescentState);
            e.Document.CommandCancelled += new CommandEventHandler(Document_CommandCancelled);
        void DocumentManager_DocumentToBeDeactivated(object sender, DocumentCollectionEventArgs e)
            ed.EnteringQuiescentState -= new EventHandler(ed_EnteringQuiescentState);
            ed.LeavingQuiescentState -= new EventHandler(ed_LeavingQuiescentState);
            e.Document.CommandCancelled -= new CommandEventHandler(Document_CommandCancelled);
        void DocumentManager_DocumentToBeDestroyed(object sender, DocumentCollectionEventArgs e)
        void DocumentManager_DocumentDestroyed(object sender, DocumentDestroyedEventArgs e)
            //If in Zero-Document state, create new drawing to make active
        #endregion
        #region Event Handlers
        public static void ed_EnteringQuiescentState(object sender, EventArgs e)
            Editor ed = sender as Editor;
            ed.WriteMessage("\nEntering Quiescence");
        void ed_LeavingQuiescentState(object sender, EventArgs e)
            ed.WriteMessage("\nLeaving Quiescence");
        void Document_CommandCancelled(object sender, CommandEventArgs e)
            ed.WriteMessage("\nA command was just cancelled.");
        #endregion
Valued Mentor
53 Kudos
Post 5 of 5
Re: Event Monitor
09-07-2012 08:54 AM in reply to: bjhuffine
Mgddbg has functionality to print events and some details to command line if you have not looked at that.
You can also find your answers @ TheSwamp
