.NET
Event for changing between modelspace and paperspace in a layout
5 REPLIES 5
268 Views, 5 Replies
Is there an event for changing between mspace and pspace in a layout. I
could find an event for switching layouts but none for switching between
mspace and pspace. Do i have to use CommandEnded to do this?
Roland Feletic
5 REPLIES 5
It looks like it, the PSPACE and MSPACE commands.
I have found that using the sample program "EventsWatcher" can be very helpful for chasing down event behavoir.
Chris Arps
Thank you for your reply, i thought that i have to do it like this 😞
Roland Feletic
cgay
The event for switching layouts is your best bet.
When you handle then event,
open the BlockTableRecord defined by the LayoutEventArgs.ID property
If you look at the name of the BlockTable record it will be either *Model_Space or *Paper_Space.
Interestingly enough, BlockTableRecord.ModelSpace is a static string that you could you to compare to, but for some reason, whenever I use it in code, AutoCAD crashes.
Well, I here is some code that was written to be added to the EventsWatcher Sample.
C
[code]
private void callback_LayoutSwitched(object sender, LayoutEventArgs e)
WriteLine(String.Format("LayoutSwitched - {0}", e.Name));
Autodesk.AutoCAD.ApplicationServices.TransactionManager tm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.TransactionManager;
Transaction tr = tm.StartTransaction();
try
DBObject dbO = tr.GetObject(e.Id, OpenMode.ForRead);
if (dbO is BlockTableRecord)
BlockTableRecord btr = (BlockTableRecord)dbO;
bool isModel = false;
isModel =(string.Compare(btr.Name.ToUpper , "*MODEL_SPACE"))==0;
WriteLine(String.Format("IsModelSpace - {0}", isModel));
tr.Commit();
catch (System.Exception ex)
tr.Abort ();
finally
tm.Dispose();
[/code]
You really don't need to go through all of that.
using Autodesk.AutoCAD.DatabaseServices;
public class MyUtils
static public bool IsModelSpaceBTR(ObjectId id)
return id == SymbolUtilityServices.GetBlockModelSpaceId(id.Database);
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5127077@discussion.autodesk.com...
C
[code]
try
tr.Commit();
tr.Abort ();
finally
tm.Dispose();
[/code]
cgay
I knew there must be a better way to check this.
Thanks Tony
C
”Boost
