.NET
.NET
Distinguished Contributor
1 Kudo
Post 1 of 6
Event for changing between modelspace and paperspace in a layout
109 Views, 5 Replies
03-27-2006 11:53 PM
Is there an event for changing between mspace and pspace in a layout. I
could find an event for switching layouts but none for switching between
mspace and pspace. Do i have to use CommandEnded to do this?
Roland Feletic
0 Kudos
Post 2 of 6
Re: Event for changing between modelspace and paperspace in a layout
03-29-2006 06:23 AM in reply to: RolandF
It looks like it, the PSPACE and MSPACE commands.
I have found that using the sample program "EventsWatcher" can be very helpful for chasing down event behavoir.
Chris Arps
1 Kudo
Post 3 of 6
03-30-2006 12:20 AM in reply to: RolandF
Thank you for your reply, i thought that i have to do it like this :-(
Roland Feletic
0 Kudos
Post 4 of 6
03-30-2006 09:07 AM in reply to: RolandF
The event for switching layouts is your best bet.
When you handle then event,
open the BlockTableRecord defined by the LayoutEventArgs.ID property
If you look at the name of the BlockTable record it will be either *Model_Space or *Paper_Space.
Interestingly enough, BlockTableRecord.ModelSpace is a static string that you could you to compare to, but for some reason, whenever I use it in code, AutoCAD crashes.
Well, I here is some code that was written to be added to the EventsWatcher Sample.
C
[code]
private void callback_LayoutSwitched(object sender, LayoutEventArgs e)
WriteLine(String.Format("LayoutSwitched - {0}", e.Name));
Autodesk.AutoCAD.ApplicationServices.TransactionManager tm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.TransactionManager;
Transaction tr = tm.StartTransaction();
try
DBObject dbO = tr.GetObject(e.Id, OpenMode.ForRead);
if (dbO is BlockTableRecord)
BlockTableRecord btr = (BlockTableRecord)dbO;
bool isModel = false;
isModel =(string.Compare(btr.Name.ToUpper , "*MODEL_SPACE"))==0;
WriteLine(String.Format("IsModelSpace - {0}", isModel));
tr.Commit();
catch (System.Exception ex)
tr.Abort ();
finally
tm.Dispose();
[/code]
*Tony Tanzillo
Post 5 of 6
03-30-2006 10:58 AM in reply to: RolandF
You really don't need to go through all of that.
using Autodesk.AutoCAD.DatabaseServices;
public class MyUtils
static public bool IsModelSpaceBTR(ObjectId id)
return id == SymbolUtilityServices.GetBlockModelSpaceId(id.Database);
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5127077@discussion.autodesk.com...
C
[code]
try
tr.Commit();
tr.Abort ();
finally
tm.Dispose();
[/code]
0 Kudos
Post 6 of 6
03-30-2006 01:21 PM in reply to: RolandF
I knew there must be a better way to check this.
Thanks Tony
C
