.NET
Event for change active layer in document
2 REPLIES 2
pva75
577 Views, 2 Replies
Hi all,
Is there event for change current (active) layer of document?
(it's not Database.ObjectModified - it's not raised).
I tried to do it with binding as:
  public void Initialize()
    var layerList = Application.UIBindings.Collections.Layers;
    layerList.PropertyChanged += new PropertyChangedEventHandler(LayerList_PropertyChanged);
And -= in Terminate, but... Autocad 2012 chashed _sometimes_!!!
Impossible to understand when it happned...
So I reject this way.
Is there other way to handle this event?
Pavel.
2 REPLIES 2
DiningPhilosopher
in reply to: pva75
Have you tried handling the system variable changed event, watching for the CLAYER system variable?
pva75
in reply to: DiningPhilosopher
It's super idea! It woks fine and not crashed.
Thanks!
Pavel.
”Boost
