.NET
event fires twice
1 REPLY 1
223 Views, 1 Reply
event fires twice
I am runing a dot net class application (dll extension) automatically when the autocad application start by adding a following lines on the acaddoc.lsp file
(defun S::STARTUP()
(command "NETLOAD" "d:\\My Documents\\Visual Studio Projects\\myapp\\bin\\myapp.dll")
My problem is that drawing events in the application like begindocclose are executed twice instead of once.
Can it be avoided?
Thanks for your help
1 REPLY 1
If events are firing more than once, it is most
likely a problem in your code, probably adding
the handler more than once.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4972410@discussion.autodesk.com...
(defun S::STARTUP()
Can it be avoided?
”Boost
