.NET
Valued Contributor
RamanSBV
Message 1 of 4 (810 Views)
Error While opening autocad using process.start
810 Views, 3 Replies
03-26-2012 05:07 AM
Error:
Activation context generation failed for "E:\SI\ProArc\Main\Source\Engineering Client\Source\AutoCAD 2012\SI.Integrations.Engg.AutoCAD2012\AutoCAD 2012 - English\acad.exe". Dependent Assembly PPClientAssembly,processorArchitecture="x86",type="x64",version="2008.1.17012.4817" could not be found. Please use sxstrace.exe for detailed diagnosis.
Please help me on this issue
Raman
It looks to me like you are trying to start the Acad.exe from a location other than where it was installed. I think you should be starting this from the AutoCAD subdirectory in  C:\Program Files\Autodesk unless you have installed this in some other location.
Valued Mentor
Mike.Wohletz
Message 2 of 4 (802 Views)
Re: Error While opening autocad using process.start
03-26-2012 06:33 AM in reply to: RamanSBV
Please post your code on how you are doing the process.start.
Any reason why you would use this method to start AutoCAD?
Valued Contributor
RamanSBV
Message 3 of 4 (800 Views)
03-26-2012 06:38 AM in reply to: Mike.Wohletz
Error while opening autocad exe
Just i am clicking on acad.exe and i am getting above error.
and In Event Viewer It is showing as
Raman
Valued Mentor
Mike.Wohletz
Message 4 of 4 (795 Views)
03-26-2012 06:46 AM in reply to: RamanSBV
