I'm still new to AutoCAD programming. I'm taking over some code from a developer that is no longer here. Right now when the code saved a resultbuffer object to xdata, I get an eregappidnotfound. Due to various forums, I believe this is because the ID is not being registered with the database before it's beign inserted.
The error is thrown on this line: XData.ToXData(partCollection);
using (Autodesk.AutoCAD.DatabaseServices.DBObject dbObj = t.GetObject(objId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)) {
DeviceName.SetDeviceName((Autodesk.AutoCAD.DatabaseServices.BlockReference)dbObj, txtDeviceName.Text);
dbObj.XData = XData.ToXData(partCollection); t.Commit(); }
The code for the ToXData function is here:
public static ResultBuffer ToXData(PartCollection Parts) { //Write out some header information ResultBuffer rb = new ResultBuffer(new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataRegAppName), XDATA_APP_NAME), new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataInteger16), XDATA_TYPE), new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataInteger16), XDATA_SUBTYPE), new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataRegAppName), XDATA_Part_NAME), new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataInteger16), Parts.Count)); //Write the individual Parts for (int i = 0; i <= Parts.Count - 1; i++) { rb.Add(new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataRegAppName), XDATA_Part_NAME + (i + 1))); rb.Add(new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataInteger16), Parts[i].Quantity)); rb.Add(new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataAsciiString), Parts[i].IdentNumber)); rb.Add(new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataAsciiString), Parts[i].Description)); rb.Add(new TypedValue(System.Convert.ToInt32(DxfCode.ExtendedDataAsciiString), Parts[i].Location)); rb.Add(new TypedValue((int)DxfCode.ExtendedDataAsciiString, System.ComponentModel.TypeDescriptor.GetProperties(typeof(Part))["Purchase"].Converter.ConvertToString(Parts[i].Purchase))); rb.Add(new TypedValue((int)DxfCode.ExtendedDataAsciiString, System.ComponentModel.TypeDescriptor.GetProperties(typeof(Part))["SpareWear"].Converter.ConvertToString(Parts[i].SpareWear))); } return rb; }
I realize that's a lot of code, but in short it takes a list of Part objects, iterates through each, then adds them to a resultbuffer. The code works when only 1 or 2 parts are in the partCollection. If 3 or more parts are in the collection, I get the eregappidnotfound error.
Can anyone point em in the right direction?
Solved by Alexander.Rivilis. Go to Solution.
eregappidnotfound error means that there is no record in RegAppTable RegAppTableRecord. Check it out. If you want to add Xdata Parts [i] then RegAppTableRecord named XDATA_Part_NAME + (i + 1) should already be in RegAppTable.
Facebook | Twitter | LinkedIn
Thank you. That confirms what I had guessed. Combining your code snippet with the code from the documentation, I was able to create a working solution. Documentation code
