There is not too much to starting a .net project. The only issue you'll have
is with debugging in Express versions (search group for work arounds).
Here is a blank project you can use as a template. You may need to change
the paths here 'Autocad 2009 CSharp Template.csproj.user' and for the
references to acdbmgd.dll and acmgd.dll as I've used the default install location.
"Roger Clayton" wrote in message news:5972464@discussion.autodesk.com...
I installed Visual C# 2008 and "Enhanced AutoCAD .NET Application
Wizard(VS2008)". When I start a project, I get the following error...
Any ideas?
