.NET
.NET
Valued Contributor
0 Kudos
Post 1 of 3
Accepted Solution
Error Saving Drawing to older version of autocad map3d
778 Views, 2 Replies
01-30-2014 06:37 AM
I am using autocad map3d 2013. I use the saveas method of autocad map3d 2013 api to save my document to previous version of autocad map3d. I got the error "The drawing contains custom objects that are not supported in previous versions. The objects cannot be save to previous version." It provide some steps to get around the error, one of which is to install autocad enablers. I check the site and found few installer. My question is what version should I download is compatible with autodesk map3d 2013?
Autocad Enablers Link: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334440&linkID=9240858#section2
My snippet is here:
db.SaveAs(strSourceDWGPath,
True, DwgVersion.AC1015, doc.Database.SecurityParameters)
Note: attached is the error I receive.
Thanks and regards,
SCLuna
Hi dgorsman,
I decided to disable the aec message box to off and it seems to work ok. I am no longer getting the error message.
*Expert Elite*
504 Kudos
Post 2 of 3
Re: Error Saving Drawing to older version of autocad map3d
01-30-2014 03:39 PM in reply to: scluna
While you can down-save to an earlier DWG version, custom objects (AEC objects are typical for AutoCAD verticals like Map3D) will never be downsaved to an earlier version even if the DWG version changes.  So you could end up with a 2004 DWG format file with 2013 Map3D objects.  You would never end up with a 2004 DWG format file with 2004 Map3D objects.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Contributor
0 Kudos
Post 3 of 3
03-15-2014 07:59 AM in reply to: dgorsman
Hi dgorsman,
SCLuna
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
