.NET
*Henk Loonstra
Message 1 of 6 (278 Views)
Error loading a Multiline style
278 Views, 5 Replies
06-17-2006 03:31 PM
Hi everyone,
Has anybody ever used db.LoadMlineStyleFile() to load a MlineStyle into a
drawing?
I succeeded in loading all styles with a workaround: insert a drawing with
all styles in it. But I think it's more elegant to use mentioned function,
and load only the requested style (instead of all).
db.LoadMlineStyleFile(sMlineStyle, sMlineFile) gives me the error:
eFileAccessErr.
But:
- filename and path are correct (i tried with "\", "\\", "/" and the AutoCAD
search path system)
- the mln file can be found
- the file is not protected or opened in another application
- the filelocation is also not protected
- no problems when manually loading a style from this file (with mlstyle >
Load)
Does anyone have an idea what causes this error eFileAccessErr to appear?
Tnx.
Henk - CAD Accent
*Henk Loonstra
Message 2 of 6 (278 Views)
Re: Error loading a Multiline style
06-24-2006 07:12 AM in reply to: *Henk Loonstra
Thank you very much.
Gr Henk
Distinguished Contributor
Alexander Rivilis
Message 3 of 6 (278 Views)
06-24-2006 01:09 PM in reply to: *Henk Loonstra
I do not know why that exception is generated (I has that error in AutoCAD 2006 and 2007), but this wrapper can help you:
[code]
class Test
class Wrapper
static int AcadVersion = Autodesk.AutoCAD.ApplicationServices.Application.Version.Major;
// For AutoCAD 2006:
[System.Security.SuppressUnmanagedCodeSecurity]
[DllImport("acdb16.dll", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Ansi,
EntryPoint = "?acdbLoadMlineStyleFile@@YA?AW4ErrorStatus@Acad@@PBD0@Z")]
extern private static ErrorStatus acdbLoadMlineStyleFile16(string mStyle, string mPath);
// For AutoCAD 2007:
[DllImport("acdb17.dll", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode,
EntryPoint = "?acdbLoadMlineStyleFile@@YA?AW4ErrorStatus@Acad@@PB_W0@Z")]
extern private static ErrorStatus acdbLoadMlineStyleFile17(string mStyle, string mPath);
public static ErrorStatus acdbLoadMlineStyleFile(string mStyle, string mPath)
switch(AcadVersion)
case 16: return acdbLoadMlineStyleFile16(mStyle, mPath);
case 17: return acdbLoadMlineStyleFile17(mStyle, mPath);
return ErrorStatus.NotImplementedYet;
// For test only
[CommandMethod("T1")]
public static void T1()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
ErrorStatus es = Wrapper.acdbLoadMlineStyleFile("METAL", @"F:\Program Files\AutoCAD 2007\ran.mln");
if (es != ErrorStatus.OK)
ed.WriteMessage("\nError: {0}", es);
[/code]
*Henk Loonstra
Message 4 of 6 (278 Views)
06-26-2006 12:18 PM in reply to: *Henk Loonstra
Hi Alexander, many thanks for the reply.
I will test this wrapper and will here let you know if it worked.
Gr Henk
schreef in bericht
news:5217888@discussion.autodesk.com...
[code]
class Test
class Wrapper
EntryPoint =
EntryPoint =
mPath)
switch(AcadVersion)
// For test only
[/code]
Alexander Rivilis
Message 5 of 6 (278 Views)
06-26-2006 12:54 PM in reply to: *Henk Loonstra
:smileyhappy: It is worked because I've tested it before posting.
*Henk Loonstra
Message 6 of 6 (278 Views)
01-17-2007 02:48 PM in reply to: *Henk Loonstra
Hi Alexander,
Sorry, for reasons I did'nt have time to implement this in my projects.
But now I did, and you're right, it works very well. Thanks a lot! :-)
Henk
schreef in bericht
news:5219049@discussion.autodesk.com...
