I created an Setup project to install my AutoCAD Addin, based in your code
"Develop Applications with VB.NET and C# / Distribute Your Application"
You can see my code below.
I get the following error in the installation
using System; using System.Collections; using System.Collections.Generic; using System.ComponentModel; using System.Configuration.Install; using System.Linq; using System.IO; using System.Reflection; using Microsoft.Win32; using Autodesk.AutoCAD.DatabaseServices; namespace eGrouWSAutoCADAddin { [RunInstaller(true)] public partial class AddinInstaller : System.Configuration.Install.Installer { StreamWriter icl_installLog; public AddinInstaller() { InitializeComponent(); } public override void Install(System.Collections.IDictionary stateSaver) { // Gets the parameter passed across in the CustomActionData. icl_installLog = new StreamWriter("_eGrouWSAutoCADAddInSetup.log"); icl_installLog.AutoFlush = true; try { m_InstallAddin(stateSaver); } finally { icl_installLog.WriteLine("Ending edit of config file"); icl_installLog.Close(); } } public void m_InstallAddin(System.Collections.IDictionary stateSaver) { try { base.Install(stateSaver); // Get the AutoCAD Applications key string sProdKey = HostApplicationServices.Current.MachineRegistryProductRootKey; string sAppName = "eGrouWSAutoCADAddin"; RegistryKey regAcadProdKey = Registry.CurrentUser.OpenSubKey(sProdKey); RegistryKey regAcadAppKey = regAcadProdKey.OpenSubKey("Applications", true); // Check to see if the "MyApp" key exists string[] subKeys = regAcadAppKey.GetSubKeyNames(); foreach (string subKey in subKeys) { // If the application is already registered, exit if (subKey.Equals(sAppName)) { regAcadAppKey.Close(); return; } } // Get the location of this module string sAssemblyPath = Assembly.GetExecutingAssembly().Location; // Register the application RegistryKey regAppAddInKey = regAcadAppKey.CreateSubKey(sAppName); regAppAddInKey.SetValue("DESCRIPTION", sAppName, RegistryValueKind.String); regAppAddInKey.SetValue("LOADCTRLS", 14, RegistryValueKind.DWord); regAppAddInKey.SetValue("LOADER", sAssemblyPath, RegistryValueKind.String); regAppAddInKey.SetValue("MANAGED", 1, RegistryValueKind.DWord); regAcadAppKey.Close(); } catch (InstallException ex) { throw new InstallException(ex.Message); } catch { throw new InstallException("Error installing addin!"); } } public override void Uninstall(System.Collections.IDictionary stateSaver) { // Gets the parameter passed across in the CustomActionData. icl_installLog = new StreamWriter("eGrouWSAutoCADAddin.log"); icl_installLog.AutoFlush = true; try { m_UninstallAddin(stateSaver); } finally { icl_installLog.WriteLine("Ending edit of config file"); icl_installLog.Close(); } } public void m_UninstallAddin(IDictionary savedState) { try { // Get the AutoCAD Applications key string sProdKey = HostApplicationServices.Current.MachineRegistryProductRootKey; string sAppName = "eGrouWSAutoCADAddin"; RegistryKey regAcadProdKey = Registry.CurrentUser.OpenSubKey(sProdKey); RegistryKey regAcadAppKey = regAcadProdKey.OpenSubKey("Applications", true); // Delete the key for the application regAcadAppKey.DeleteSubKeyTree(sAppName); regAcadAppKey.Close(); } catch { } base.Uninstall(savedState); } } }
Links you have provided, is not supposed to build an installer. In below links you can find the details to build installer so that you can install it in your PC. Please have a look.
