.NET
error in document object creation
2 REPLIES 2
596 Views, 2 Replies
using System;
using System.Threading;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.IO;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Interop.Common;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
namespace application
class Program
static void Main(string[] args)
Document acDoc = Application.DocumentManager.MdiActiveDocument;
Working Environment:-
  1. Visual Studio 2010
  2. AutoCAD 2011
  3. C#
After run following error will occure
An unhandled exception of type 'System.TypeLoadException' occurred in mscorlib.dll
Additional information: Method 'CopyTo' in type 'Autodesk.AutoCAD.ApplicationServices.DocumentCollection'
from assembly 'acmgd, Version=18.1.0.0, Culture=neutral, PublicKeyToken=null' does not have an implementation ."
2 REPLIES 2
Alexander.Rivilis
I see what you're trying to create a standalone application (exe-file). In this case you can not use AutoCAD. NET API (ie acmgd.dll, acdbmgd.dll, accoremgd.dll, etc)
Facebook | Twitter | LinkedIn
Expert Elite Member
Although you can license the RealDWG SDK to add DWG capability to your own app. Brief explanation here - http://adndevblog.typepad.com/autocad/2012/03/readingwriting-dwg-files-from-a-standalone-application....
Cheers,
Stephen Preston
Autodesk Developer Network
”Boost
