.NET
Distinguished Contributor
jmaeding
Message 1 of 11 (617 Views)
Error during save, recommend recover...nag screen, how to not display
617 Views, 10 Replies
09-28-2012 06:31 PM
I am batching through files and purfging reg apps.
Some files at our office, usually from 2006 and below, give the error dialog "error during saver, recommend recover...".
I have no problem with a file being skipped because it had an error, but that nag screen is stopping the batch process.
I am reading the drawings in through dbx, not operating on an open drawing in the editor.
Is there some way to keep the db.saveas method from showing this dialog?
I am on version 2012.
thanks
internal protected virtual unsafe Human()
http://onesmallstepforcad.com/
Alfred.NESWADBA
Message 2 of 11 (575 Views)
Re: Error during save, recommend recover...nag screen, how to not display
10-01-2012 02:06 PM in reply to: jmaeding
ever tried to run wblock/clone/xxxx instead of saveas?
- alfred -
Alfred NESWADBA
jmaeding
Message 3 of 11 (572 Views)
10-01-2012 02:44 PM in reply to: Alfred.NESWADBA
wblock method would not be a good approach, as its far too agressive a cleaning mechanism.
I am running on thousands of drawings and do not want to change anything but the excess app ids.
I cannot touch handles or grouping.
Do you have ideas in mind that accomplish this?
Alfred.NESWADBA
Message 4 of 11 (567 Views)
10-01-2012 03:06 PM in reply to: jmaeding
then another method could be not to open the defect database, but to use insert-like functionality into a new database and then run the saveas with the new database.
You also may run the audit-function on each of the database resident objects, maybe this cleans up some defects that makes "saveas" available without interrupting dialog.
Good luck, - alfred -
Alfred NESWADBA
jmaeding
Message 5 of 11 (559 Views)
10-01-2012 05:47 PM in reply to: Alfred.NESWADBA
well, the problem is the "realdwg" exe that adesk made for me in the past, did not show these messages.
It just failed or ran.
I do not want to do any extraction and making new drawings, you are making a ton of assumptions about how well that matches the original drawing.
I have watched adesk mess this up with its civil batch converter, it takes a while to encounter and notice all the little problems that come up.
The dumb thing is, I believe its saving the drawing successfully. One of the reasons I use the tool is simply to save drawings to current version, so its all working except for the wonderful message.
ADN Support Specialist
Balaji_Ram
Message 6 of 11 (537 Views)
10-03-2012 04:17 AM in reply to: jmaeding
Hi James,
Can you please try the sample code from a Devnote that Stephen posted in his recent reply ?
http://forums.autodesk.com/t5/Autodesk-ObjectARX/Hiding-AutoCAD-messages-while-processing-on-drawing...
Balaji
Developer Technical Services
Autodesk Developer Network
jmaeding
Message 7 of 11 (522 Views)
10-03-2012 08:55 AM in reply to: Balaji_Ram
Thanks for the reply Balaji,
I am not a C++ guy, though I can read and understand what he is doing. I just have never even done a hello world prog in VS with C++ so maybe time to start.
In the past, I did not run into this because autodesk compiled an exe for me that cleaned regapps. I even have the code, but no realdwg license to compile for 2010+, and no skills currently to make sure I am compiling correctly.
Is there a chance I could get autodesk to compile the exe for me?
If not, I essentially have to either hire someone to help me or live with the nag screens.
Can you help?
Balaji_Ram
Message 8 of 11 (494 Views)
10-05-2012 09:08 AM in reply to: jmaeding
Hi James,
If you can please share the source code and let me know who in Autodesk built the earlier version of the exe, I can get in touch to find if an updated version of it is available for 2010+.
If not, I will enquire with my colleagues to find out if we can build it from the source and give it you.
Since ADN usually do not distribute binaries other than a few OCX controls, I am not sure if I am permitted to build the code and give it to you. But I will surely find out and try.
Balaji
jmaeding
Message 9 of 11 (488 Views)
10-05-2012 09:48 AM in reply to: Balaji_Ram
I will email you the full source code, in the mean time, the portion that cleaned things was this:
// This is command 'PURGEAPP'
bool asdkRemoveApp(CString csArgFile)
	Acad::ErrorStatus es;
	AcDbDatabase *pDb=new AcDbDatabase(false,true);
	acdbHostApplicationServices()->setWorkingDatabase(pDb);
	if(Acad::eOk!=pDb->readDwgFile(csArgFile))
		//AfxMessageBox("Could not Read "+csArgFile);
		return false;
	pDb->setRetainOriginalThumbnailBitmap(true);
	// Get the RegAppTable
	AcDbRegAppTable* pRegTable;
	pDb->getRegAppTable(pRegTable,AcDb::kForRead);
	// Create an iterator of the RegAppTable
	AcDbRegAppTableIterator* it;
	if((es = pRegTable->newIterator(it,Adesk::kTrue,Adesk::kTrue)) != Acad::eOk)
		pRegTable->close();
		return false;
	pRegTable->close();
	AcDbObjectIdArray idArray;
	// iterate through the RegAppTable
	while(!it->done() )
		// get a RegAppRecord
		AcDbObjectId recId;
		//if((es = it->getRecord(rec,AcDb::kForRead)) != Acad::eOk)
		if((es = it->getRecordId(recId)) != Acad::eOk)
			delete it;
			return false;
		if(recId.isValid())
			idArray.append(recId);
		it->step();
	delete it;
	// Now through the Layer Filters...this will simply remove them all.
	AcDbLayerTable *pLT=NULL;
	if(Acad::eOk==pDb->getLayerTable(pLT,AcDb::kForRead))
		AcDbObjectId ltExtDictId=pLT->extensionDictionary();
		pLT->close();
		AcDbDictionary *pLTExtDict=NULL;
		if(Acad::eOk==acdbOpenObject(pLTExtDict,ltExtDictId,AcDb::kForRead))
			AcDbDictionary *pLFDict=NULL;
			if(Acad::eOk==pLTExtDict->getAt(_T("ACAD_LAYERFILTERS"),(AcDbObject*&)pLFDict,AcDb::kForWrite))
				pLFDict->setTreatElementsAsHard(false);
				AcDbDictionaryIterator *pDictItr=pLFDict->newIterator();
				pLFDict->close();
				for(;!pDictItr->done();pDictItr->next())
					AcDbObjectId ltFilterId=pDictItr->objectId();
					if(ltFilterId.isValid())
						idArray.append(ltFilterId);
				delete pDictItr;
			pLTExtDict->close();
	else
		return false;
	pDb->purge(idArray);
	for(int i=0;i<idArray.length();i++)
		AcDbObject *pObj=NULL;
		if(Acad::eOk==acdbOpenObject(pObj,idArray[i],AcDb::kForWrite))
			if(Acad::eOk!=pObj->erase())
				pObj->close();
				return false;
			pObj->close();
		else
			return false;
	pDb->saveAs(csArgFile);
	acdbHostApplicationServices()->setWorkingDatabase(NULL);
	delete pDb;
	return true;
 I would have asked specific permission from Stephen Preston to post the code, but Kean's post in C# does exactly the same thing so this is just the C++ version.
He was the one who did the last compile for me, though Calyton Hotson did the original.
thanks for considering the realdwg compile.
Balaji_Ram
Message 10 of 11 (438 Views)
10-10-2012 02:46 AM in reply to: jmaeding
Hi James,
Here are the steps that I tried, but havent got the recover dialog. Can you see if I am missing some step ?
The attachment is ~3MB recording so I am sharing it using dropbox. Here is the link :
https://www.dropbox.com/s/f8uche9w3qw416a/Demo.zip
Balaji
