.NET
Error Decrypting Data (Acad 2011)
24 REPLIES 24
Message 1 of 25
hawesan
5207 Views, 24 Replies
I get the following error in vb .net macro :
System.Runtime.InteropServices.COMException was unhandled by user code
ErrorCode=-2145386153
HelpLink="C:\Program Files\Autodesk\ACADM 2011\HELP\OLE_ERR.CHM#-2145386153"
Message="Error Decrypting Data"
Source="AutoCAD"
StackTrace:
at Autodesk.AutoCAD.Interop.AcadDocumentsClass.Open(String Name, Object ReadOnly, Object Password) at dwgdb1.addDrawings(String& typestr) in C:\Users\harrison.pe\Documents\Visual Studio 2008\Projects\GEA_DrawingDB\dwgdb1.vb:line 346 at dwgdb1.CommandButton4_Click(Object eventSender, EventArgs eventArgs) in C:\Users\harrison.pe\Documents\Visual Studio 2008\Projects\GEA_DrawingDB\dwgdb1.vb:line 557 at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
InnerException:
Works fine in Acad 2010 ! see attached image from visual studio debug
System = Windows 7 (64bit) Autocad Mechanical 2011
24 REPLIES 24
Message 21 of 25
skeletank
in reply to: Aaron.Warnke
Works for me as well.  Thank you very much Gaston! Smiley Happy
Message 22 of 25
matus.brlit
in reply to: hawesan
or you can just catch the exception, i guess
you don't get errors from handled exceptions and you can also test if the problem is because of different application creating the drawing, or because of the potential errors
Message 23 of 25
hgasty1001
in reply to: matus.brlit
Yes, you can trap the COMexception (not a simple Exception), but doing so ( did you?), you still have to set the variable DWGCHECK=2 and try to open the file again in order to get, may be, the drawing opened.
Gaston Nunez
Message 24 of 25
hgasty1001
I think that a better aproach is to set DWGCHECK=2, then try to open the drawing as usual, get the drawing opened and check the DwgFileWasSavedByAutodeskSoftware property in order to take some action.
Gaston Nunez
Message 25 of 25
API991
Great! This solved my problem also! Many thanks!!
”Boost
