.NET
Error debugging in Autocad 2011
1 REPLY 1
BellwetherBill
712 Views, 1 Reply
I recently installed Autocad 2012 and the objectarx2012 sdk. Now when I try to debug an application in 2011 using VS 2008 I get the following error message:
Exception has been thrown by the target of an invocation. Error at object 'System.Windows.Data.Binding' in markup file 'AcWindows;component/AppFrame/AcAppFrame.xaml'.
When I select the continue button I can "Netload" the application but when I type the command and get the "Unknown command" message. I am using projects that worked before and I am able to load and run them while not debugging.
Does anyone know what happened?
1 REPLY 1
I had copy local for the references to the managed classes set to true.
Sorry........
”Boost
