.NET
luisibad
357 Views, 2 Replies
error 91
Hi! I'm not sure if I should publish this post here, but I'm trying to do something between Excel and Autocad with VSTO and Autocad type library and all this with vb.net
This is part of my code:
Dim PTRange, XRange, YRange, ZRange, CDRange, HTRange As Excel.Range
Dim North, Easte, Elevation As Double
Dim BlockName As String = "UTM"
Dim PtXYZ As Double()
Dim ValScale, ARotation As Double
ValScale = Convert.ToDouble(1)
ARotation = Convert.ToDouble(0)
Try
CAD_App = GetObject(, "AutoCAD.Application")
CAD_Doc = CAD_App.ActiveDocument
Try
For I AsInt16 = Fila To FilaEnd
'PTRange = XlSheet_GetValues.Cells(I, 1)
'Punto = PTRange.Value
YRange = XlSheet_GetValues.Cells(I, 2)
North = Convert.ToDouble(YRange.Value)
XRange = XlSheet_GetValues.Cells(I, 3)
Easte = Convert.ToDouble(XRange.Value)
ZRange = XlSheet_GetValues.Cells(I, 4)
Elevation = Convert.ToDouble(ZRange.Value)
'Cota = ZRange.Value
'CDRange = XlSheet_GetValues.Cells(I, 5)
'Descripcion = CDRange.Value
PtXYZ = NewDouble() {Este, Norte, Elevation}
'PtXYZ(0) = Este : PtXYZ(1) = Norte : PtXYZ(2) = Elevation
Dim Acad_BlockInsert As AcadBlockReference
'CAD_Model.InsertBlock(PtXYZ, BlockName, ValScale, ValScale, ValScale, ARotation)
Acad_BlockInsert = CAD_Model.InsertBlock(PtXYZ, BlockName, ValScale, ValScale, ValScale, ARotation) ' HERE IS THE PROBLEM
'If Acad_BlockInsert.HasAttributes Then
'ArrayATT = Acad_BlockInsert.GetAttributes
Next I
Catch ex AsException
' I got this error number 91 and it meant that object reference not set to an instance of an object
MsgBox("Error número " & Err.Number & vbNewLine & "Descripción del Error: " & Err.Description)
EndTry
If Err.Number = 429 Then
MsgBox("AutoCAD no se encuentra activada o el programa no esta instalado en el EQUIPO", MsgBoxStyle.Critical, "ERROR DE CONEXION (EXCEL - AUTOCAD)")
EndIf
EndTry
So, I can't insert the block because I got the err.number 91.
I would like to know if there will be some way to sort it out , or It's not posible to create this kind of connection between Excel and AutoCAD with VB.NET
I'll appreciate any help
2 REPLIES 2
Alfred.NESWADBA
in reply to: luisibad
does a block named "UTM" exist in the current drawing?
Does the exception occure in the first loop or in any further loop?
Have you verified the variable-content for insertion-point?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
norman.yuan
It is obviously that you did not show enough code to find the cause of the error, because the error is occured at
and the error seems to indicate the object CAD_Model (which I assume is the MOdelSpace of active drawing) is Nothing.
Your code did not show how/where it is declare. But since the AutoCAD.Application is just instantiated in the shown code, and logically, CAD_Model variable can only be assigned to an valid AcadModelSpace object after that, which can not be seen in your code. Thus, the error says exactly what is wrong: CAD_Model is not assigned.
If the current drawing is the target drawing, the code shouyld be like this:
Try
CAD_Model=CAD_Doc.ModelSpace
Norman Yuan
Drive CAD With Code
”Boost
