.NET
Erase last object
13 REPLIES 13
Message 1 of 14
1442 Views, 13 Replies
Erase last object
Hey everyone, In AutoCAD, i can type "erase" and then "last" into the commandline and it will automatically select and erase the last object i created. How is this accomplished in C#? I'm generating a polyline to automatically calculate areas, but i would like that polyline to vanish once the area has been measured. Thanks Vince
13 REPLIES 13
Message 2 of 14
hgasty1001
There is a SelectLast option:
PromptSelectionResult acSSPrompt;
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
acSSPrompt = ed.SelectLast();
Gaston Nunez
Message 3 of 14
in reply to: hgasty1001
Ok that helps, what would i use to delete what i selected with the editor?
Vince
Message 4 of 14
hgasty1001
You should start a transaction, get the last object (as entity)  erase it (entity.erase), and commit the transaction and that's it. Like this (not tested, and translated from VB)
[CommandMethod("ELAST")]
public void EraseObj()
	Document acDoc = Application.DocumentManager.MdiActiveDocument;
	Database acCurDb = acDoc.Database;
	using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) {
		acSSPrompt = ed.SelectLast;
		Entity ent;
		SelectionSet ss = acSSPrompt.Value;
		if (ss.Count > 0) {
			ent = acTrans.GetObject(ss.Item(0).ObjectId, OpenMode.ForWrite);
			ent.Erase();
		acTrans.Commit();
Gaston Nunez
Message 5 of 14
I have not used it and of course 'not supported' but maybe you can search for
Autodesk.AutoCAD.Internal.Utils.EntLast();
and see if people have had success
Message 6 of 14
Thanks for this sample, i'm having an issue with the line:
 ent = acTrans.GetObject(ss.(0).ObjectId, OpenMode.ForWrite);
Visual Studio 2010 and AutoCAD 2012 are telling me that there is no definition for ss.item and thus i cannot compile. As i missing  a reference?
Vince
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Colors;
Message 7 of 14
Thanks jeff, i'll have a look into this as well.
Cheers
Vince
Message 8 of 14
hgasty1001
SelectionSet  it's part of the EditorInput, and I see you are "using" it, so I have no idea why VS is telling you that. Any way the correct sintax is : ss(index).ObjectId without a dot after ss.
Gaston Nunez
Message 9 of 14
Ok, so i've got this now:
Entity ent;
if (ss.Count > 0)
ent = acTrans.GetObject(ss(0).ObjectId, OpenMode.ForWrite);
ent.Erase();
acTrans.Commit();
But the error I have is 'ss' is a 'variable' but is used like a 'method'
Message 10 of 14
hgasty1001
My mistake (i'm a vb guy), just change ss(0) by ss[0].
Gaston Nunez
Message 11 of 14
Haha didn't even notice that. Now when i change it to ss[0], i get
Error 1 Cannot implicitly convert type 'Autodesk.AutoCAD.DatabaseServices.DBObject' to 'Autodesk.AutoCAD.DatabaseServices.Entity'. An explicit conversion exists (are you missing a cast?) C:\Users\user\Dropbox\Programming\Cad\Cad\TheProgram\Drawing Commands\Copy of AREA.cs 28 27 Commands
if (ss.Count > 0)
ent = acTrans.GetObject(ss[0].ObjectId, OpenMode.ForWrite);
ent.Erase();
acTrans.Commit();
Message 12 of 14
Scratch that, fixed it 😉
Entity ent;
if (ss.Count > 0)
ent = acTrans.GetObject(ss[0].ObjectId, OpenMode.ForWrite) as Entity;
ent.Erase();
acTrans.Commit();
Thanks a million for your help!
Message 13 of 14
hgasty1001
Glad to help you, sorry the mistake, i feel much comfortable with vb 'cause I'd like to see "End this", "End That"... instead of a lot of brackets at the end of a block of code.
Gaston Nunez
Message 14 of 14
No worries, thanks again!
”Boost
