.NET
entity.get_Layer()
6 REPLIES 6
Nawara17
297 Views, 6 Replies
entity.get_Layer()
anybody knows why entity.get_layer() cannot be used explicity?
I am trying to get an entity's layer name. but when I use ent.get_layer(), the following error appear:
'Autodesk.AutoCAD.DatabaseServices.Entity.Layer.get': cannot explicitly call operator or accessor
and if I used ent.Layer as I saw in other topics in this discussions, it seems that it doesn't defined in my project. it is not appearing in ent properties list and it gives this error:
'Autodesk.AutoCAD.DatabaseServices.Entity' does not contain a definition for 'layer'
BTW, I am using VS2003, C#.
thanks in advance
Noora
6 REPLIES 6
in reply to: Nawara17
There's been quite a bit of confusion here as a result
of people posting questions but not mentioning what
release of AutoCAD they're working with.
The differences are significant between 2005 and
2006 (and I'm finding that in 2007/VS2005, there
are massive problems with code that worked fine
in 2006/VS2003).
So, for starters, what release of AutoCAD is that ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5245736@discussion.autodesk.com...
thanks in advance
Noora
Nawara17
I am using autocad2006
Autodesk.AutoCAD.DatabaseServices.Entity does have a string property "Layer"
in Acad2006.
wrote in message news:5246568@discussion.autodesk.com...
Nawara17
ya, but I think the problem is with VS2003.
becuase I opened my project in VC# 2005 Express edition, and i used layer property it doesn't give me an error and it works, but in VS2003 it seems that this property is not defined there.
I don't know how to solve this bug? becuase i want to create my project using VS2003.
Intellisense in 2003 has problems.
You may not see it listed, but it certainly is there
and it works.
wrote in message news:5246916@discussion.autodesk.com...
Nawara17
Thanks Tony.
It works 🙂
”Boost
