.NET
Entity advice
10 REPLIES 10
Message 1 of 11
darpz
536 Views, 10 Replies
Entity advice
Hi, i'm starting to develop a .NET plugin, so i'd like to have some advice from you experts 😉
I've just to draw some rectangles on a map (a 2D layer) an then set a label that show me the name and then set other "invisible" properties that describe my area.
I thought to represent this with a region and put a label on it; I'd like that these entities have a kind of relation, like move togheter etc. and finally store into this area some properties, like strings and numbers.
i have to create a custom entity with C++ or there is some other (easier) way to do this?
thanks in advance....
Bye.
Tags (2)
10 REPLIES 10
Message 2 of 11
adadnet
in reply to: darpz
hi
database services contain a GROUP dbobject, which can take the respective label as name and any entities you want associated with it can be appended (and removed), although they remain individually editable.
felix
Message 3 of 11
VB_Autocad_guy
in reply to: adadnet
I don't think you have to use C++, you could use any .NET language.
Visual Basic, C++, C# and there's some others.
But if you are learning why not try Visual basic.
Have fun, the adventure has only begun
 Smiley Happy
Message 4 of 11
kdub_nz
in reply to: VB_Autocad_guy
VB_Autocad_guy
If the op wants custom objects c++ ARX is the option.
.NET managed does NOT create custom objects.
Regards
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Message 5 of 11
dgorsman
in reply to: kdub_nz
C++ *is* the only way for custom objects, but there may be some other options that are easier to implement and friendlier to other users: static or dynamic (stretchable) block with attributes, grouped entities, either with XDATA or Extension Dictionaries/XRecords both come to mind.
As I always say, code is the end product, not the start.  There needs to be a lot of prior planning, outlines, object model research, etc. prior to writing a single line of code.
Message 6 of 11
kdub_nz
in reply to: dgorsman
true that !
Message 7 of 11
VB_Autocad_guy
Thanks Kerry,
Custom Objects huh? So you can do that in Arx huh?
Thanks for clarification.
Message 8 of 11
darpz
in reply to: darpz
Thanks guys, i think i will wait a white before try to create c++ custom object.
The "Group of Entities" solution seems to be a good choice!
So i will try to put a region and a label with the name in a group, i have just another question:
Where can i put the other properties of my object, i'd like to have a group with its (invisible)
data field like a C# class; I read i can use XData, correct?
There's a tutorial that explain how to use it?
Thanks again
Cheers.
dp
Message 9 of 11
matus.brlit
in reply to: darpz
the way to create "custom objects" in .NET is the Overrule API
XData is an easy way to stick some data to entities, but it has limitations (i think there's a maximum size of the XData), it's recomended to use ExtensionDictionary, which is also quite simple
you have to create the ExtensionDicionary with DBObject.CreateExtensionDicionary() and then add some Xrecords in it
Message 10 of 11
kdub_nz
in reply to: matus.brlit
No,  words have meanings.
Message 11 of 11
matus.brlit
Kerry, I'm pretty sure, your words also have some meaning. I just don't get it.
”Boost
