.NET
Enter key behavour Multiline textbox on palette?
2 REPLIES 2
mahersy
276 Views, 2 Replies
I am having trouble starting a new line with the enter key in a text box on a palette. I can load text with enters and it displays the return on the next line but when i press enter it do not return to the next line. I have set:
Multiline =True
Wordwrap = false
AcceptsTab=true
AcceptsEnter=True
2 REPLIES 2
in reply to: mahersy
Use this control in lieu of the TextBox, and it should
solve the problem:
using System.Windows.Forms;
namespace CaddZone.AutoCAD.UI.Controls
public class MultilineTextBox : System.Windows.Forms.TextBox
public MultilineTextBox()
: base()
this.Multiline = true;
const int DLGC_WANTCHARS = 0x0080;
const int WM_GETDLGCODE = 0x0087;
protected override void WndProc( ref Message m )
if( this.AcceptsReturn && m.Msg == WM_GETDLGCODE )
m.Result = new IntPtr( DLGC_WANTCHARS );
else
base.WndProc( ref m );
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5328599@discussion.autodesk.com...
Multiline =True
Wordwrap = false
AcceptsTab=true
AcceptsEnter=True
mahersy
Thank for the help.
For the c# handycaped like me
Imports System.Windows.Forms
Namespace CaddZone.AutoCAD.UI.Controls
Public Class MultilineTextBox
Inherits System.Windows.Forms.TextBox
Public Sub New()
Me.Multiline = True
End Sub
constant DLGC_WANTCHARS as Interger = &H80
constant WM_GETDLGCODE as Integer= &H87
Protected Overrides Sub WndProc(ByRef m As Message)
If Me.AcceptsReturn And m.Msg = WM_GETDLGCODE Then
m.Result = New IntPtr(DLGC_WANTCHARS)
Else
MyBase.WndProc( m)
End Sub
End Class
End Namespace Message was edited by: Mahersy
”Boost
