.NET
Active Contributor
xdbk07
Message 1 of 11 (332 Views)
eNotAplicable error
332 Views, 10 Replies
05-17-2013 03:08 AM
Hi All,
I met error "eNotAplicable" when I try to turn off object in viewports each. What happen?
Well, I forgot to mention that if the layout is not active, all viewport's Number property would be -1 and you cannot turn it on or off. So, you need to set each layout as current before turn viewport on the layout on/off. Here is sample code that toggle viewports on one or more layouts on or off:
public class MyCommands
private static bool _vpOn = true;
[CommandMethod("ToggleVP")]
public static void RunToggleViewport()
_vpOn = !_vpOn;
ToggleViewport(_vpOn);
private static void ToggleViewport(bool vpOn)
Document dwg = Application.DocumentManager.MdiActiveDocument;
Editor ed = dwg.Editor;
Database db = dwg.Database;
LayoutManager lManager = LayoutManager.Current;
string curLayout = lManager.CurrentLayout;
try
using (Transaction tran = db.TransactionManager.StartTransaction())
DBDictionary layDic = (DBDictionary)tran.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
foreach (DBDictionaryEntry entry in layDic)
if (entry.Key.ToUpper() != "MODEL")
Layout layout = (Layout)tran.GetObject(entry.Value, OpenMode.ForRead);
lManager.CurrentLayout = layout.LayoutName;
ed.WriteMessage("\nLayout: {0}", layout.LayoutName);
ObjectIdCollection vpIds = layout.GetViewports();
foreach (ObjectId id in vpIds)
Viewport vp = (Viewport)tran.GetObject(id, OpenMode.ForRead);
ed.WriteMessage("\n =>Viewport number: {0}", vp.Number);
if (vp.Number != 1)
vp.UpgradeOpen();
vp.On = vpOn;
tran.Commit();
finally
if (lManager.CurrentLayout != curLayout)
lManager.CurrentLayout = curLayout;
Moderator
Alexander.Rivilis
Message 2 of 11 (308 Views)
Re: eNotAplicable error
05-17-2013 09:31 AM in reply to: xdbk07
xdbk07 wrote:
Hi All,
How you try to turn off object in viewports? Please provide your's code.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
xdbk07
Message 3 of 11 (304 Views)
05-17-2013 09:57 AM in reply to: xdbk07
Thanks for help.
Here is the code:
    Public Sub OFFVIEWPORT()
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim lays As DBDictionary = acTrans.GetObject(acCurDb.LayoutDictionaryId, OpenMode.ForRead)
            For Each item As DBDictionaryEntry In lays
                If item.Key <> "Model" Then
                    Dim lay As Layout = TryCast(acTrans.GetObject(item.Value, OpenMode.ForRead, False, True), Layout)
                    For Each vpid As ObjectId In lay.GetViewports()
                        Dim vp As Autodesk.AutoCAD.DatabaseServices.Viewport = TryCast(acTrans.GetObject(vpid, OpenMode.ForWrite, True, True), Autodesk.AutoCAD.DatabaseServices.Viewport)
                        vp.On = False 'Error
                       'vp.on=true 'is OK
                    Next
                End If
            Next
            acTrans.Commit()
        End Using
    End Sub
norman.yuan
Message 4 of 11 (288 Views)
05-17-2013 02:08 PM in reply to: xdbk07
You may want to try the code like this:
           ''you cannot turn off viewport the layout itself is shown in it
           If vp.Number<>1 Then
              vp.On=False
          End If
    Next
Active Contributor
xdbk07
Message 5 of 11 (279 Views)
05-18-2013 05:02 AM in reply to: norman.yuan
I changed the code but it did not solve the proplem. An error occurred while processing your guidance. At "Model space" error is: "eNotAplicable" or at "layout" error is "Autocad application has stopped working".
norman.yuan
Message 6 of 11 (272 Views)
05-18-2013 06:13 AM in reply to: xdbk07
        _vpOn = !_vpOn;
        try
                            if (vp.Number != 1)
                                vp.UpgradeOpen();
                                vp.On = vpOn;
                tran.Commit();
        finally
Active Contributor
xdbk07
Message 7 of 11 (239 Views)
05-20-2013 12:30 AM in reply to: norman.yuan
Thanks for help,
It's work but the progress is too slow. It's takes some minutes to turn off all viewports of about 10 layouts. I think because Acad regen after switch layout each. Please give me a suggestion.
norman.yuan
Message 8 of 11 (220 Views)
05-21-2013 06:33 AM in reply to: xdbk07
You may play around with "Layout Regen Options" ("Options" dialog box, tab "System"). Try select different radio button to run the code.
The 3 radion buttons are corresponding to the 3 values of system variable " LAYOUTREGENCTL" (0, 1, and 2). With the best result of your try, you can then set the system variable to the desired value before runnong your code to toggle viewports on layouts on and off, and then set the system variable back at the end of your code.
Active Contributor
ditran
Message 9 of 11 (216 Views)
05-21-2013 08:14 AM in reply to: norman.yuan
Can you help me the code?
norman.yuan
Message 10 of 11 (199 Views)
05-21-2013 02:33 PM in reply to: ditran
What code you need help? Do you mean how to set system variable "LAYOUTREGNCTL"? Something like this:
//Save current value of the system variable
object oldValue=Application.GetSysVariable("LAYOUTREGENCTL");
//Set the system's variable to 0, 1, or 2, whichever is the best for the following operation
Application.SetSysVariable("LAYOUTREGENCTL", 0);
//Turn on/off viewport on layout, as discussed in previous posts
//Afterward, restore the system variable back to its original value
Application.SetSysVariable("LAYOUTREGENCTL", oldValue);
