.NET
eNoInputFiler Error
6 REPLIES 6
NLeininger
1137 Views, 6 Replies
eNoInputFiler Error
After running the following code block, the drawing becomes unusable, as every time I run ReadDwgFile after a successful run I get "ENoInputFiler."
foreach (ObjectId attributeObjId in anotherBlkTableRecord)
                                            AttributeDefinition attributeDefinition = (trans.GetObject(attributeObjId, OpenMode.ForRead).GetType() == typeof(AttributeDefinition) ?
                                                (AttributeDefinition)trans.GetObject(attributeObjId, OpenMode.ForRead) : null);
                                            if (attributeDefinition != null)
                                                if (string.Compare(attributeDefinition.Prompt, attributePrompt, true) == 0)
                                                    return GetAttributeValueStep2(activeDb, workingBlock, attributeDefinition.Tag);
Am I doing something wrong?
6 REPLIES 6
_gile
in reply to: NLeininger
Look at the 'as' operator.
	    trans.GetObject(attributeObjId, OpenMode.ForRead) as AttributeDefinition;
        if (attributeDefinition.Prompt == attributePrompt)
 Or, more efficient, check the underlying type of the ObjectId
RXClass attDefClass = RXClass.GetClass(typeof(AttributeDefinition));
	if (attributeObjId.ObjectClass == attDefClass)
	        (AttributeDefinition)trans.GetObject(attributeObjId, OpenMode.ForRead);
Gilles Chanteau
GileCAD
GitHub
NLeininger
in reply to: _gile
I've re-written the code as you suggested.  I still get the error when trying to read a drawing, though.
using (Autodesk.AutoCAD.DatabaseServices.Database acDb = new Autodesk.AutoCAD.DatabaseServices.Database(false, false))
                        acDb.ReadDwgFile(fileToProcess, FileShare.ReadWrite, false, string.Empty);
The bolded line is throwing the error.
fenton.webb
we need a buildable sample to look at with sample dwg - as far as I can tell, your code doesn't show anything wrong
Fenton Webb
AutoCAD Engineering
NLeininger
in reply to: fenton.webb
I'm trying to attach a zip file with the program and sample drawing, but it keeps telling the file is corrupted.
Balaji_Ram
I had a similar problem in attaching files to another post.
Please try again and if does not work, you can share it using dropbox or mail it to me.
Balaji
Developer Technical Services
Autodesk Developer Network
Balaji_Ram
Hi Neil,
Thanks for mailing the sample project to reproduce the behavior.
Iam posting the code snippet that I sent in my reply to you for future reference.
To resolve it, you need to lock the document or create the database without associating with the current document.
Document doc = Application.DocumentManager.MdiActiveDocument;
using (DocumentLock docLock = doc.LockDocument())
Or create the database without associating it with the active document as :
using (Autodesk.AutoCAD.DatabaseServices.Database acDb = new Autodesk.AutoCAD.DatabaseServices.Database(false, true))
Balaji
”Boost
