.NET
Active Contributor
NLeininger
Message 1 of 7 (353 Views)
eNoInputFiler Error
353 Views, 6 Replies
06-17-2013 02:18 PM
After running the following code block, the drawing becomes unusable, as every time I run ReadDwgFile after a successful run I get "ENoInputFiler."
foreach (ObjectId attributeObjId in anotherBlkTableRecord)
                                            AttributeDefinition attributeDefinition = (trans.GetObject(attributeObjId, OpenMode.ForRead).GetType() == typeof(AttributeDefinition) ?
                                                (AttributeDefinition)trans.GetObject(attributeObjId, OpenMode.ForRead) : null);
                                            if (attributeDefinition != null)
                                                if (string.Compare(attributeDefinition.Prompt, attributePrompt, true) == 0)
                                                    return GetAttributeValueStep2(activeDb, workingBlock, attributeDefinition.Tag);
Am I doing something wrong?
_gile
Message 2 of 7 (335 Views)
Re : eNoInputFiler Error
06-18-2013 12:42 AM in reply to: NLeininger
Look at the 'as' operator.
	    trans.GetObject(attributeObjId, OpenMode.ForRead) as AttributeDefinition;
        if (attributeDefinition.Prompt == attributePrompt)
 Or, more efficient, check the underlying type of the ObjectId
RXClass attDefClass = RXClass.GetClass(typeof(AttributeDefinition));
	if (attributeObjId.ObjectClass == attDefClass)
	        (AttributeDefinition)trans.GetObject(attributeObjId, OpenMode.ForRead);
Gilles Chanteau
Active Contributor
NLeininger
Message 3 of 7 (298 Views)
06-20-2013 11:50 AM in reply to: _gile
I've re-written the code as you suggested.  I still get the error when trying to read a drawing, though.
using (Autodesk.AutoCAD.DatabaseServices.Database acDb = new Autodesk.AutoCAD.DatabaseServices.Database(false, false))
                        acDb.ReadDwgFile(fileToProcess, FileShare.ReadWrite, false, string.Empty);
The bolded line is throwing the error.
ADN Support Specialist
fenton.webb
Message 4 of 7 (275 Views)
06-24-2013 09:39 AM in reply to: NLeininger
we need a buildable sample to look at with sample dwg - as far as I can tell, your code doesn't show anything wrong
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Active Contributor
NLeininger
Message 5 of 7 (271 Views)
06-24-2013 10:30 AM in reply to: fenton.webb
I'm trying to attach a zip file with the program and sample drawing, but it keeps telling the file is corrupted.
Balaji_Ram
Message 6 of 7 (251 Views)
Re: eNoInputFiler Error
06-24-2013 09:12 PM in reply to: NLeininger
I had a similar problem in attaching files to another post.
Please try again and if does not work, you can share it using dropbox or mail it to me.
Balaji
Balaji_Ram
Message 7 of 7 (215 Views)
07-04-2013 06:34 AM in reply to: NLeininger
Hi Neil,
Thanks for mailing the sample project to reproduce the behavior.
Iam posting the code snippet that I sent in my reply to you for future reference.
To resolve it, you need to lock the document or create the database without associating with the current document.
Document doc = Application.DocumentManager.MdiActiveDocument;
using (DocumentLock docLock = doc.LockDocument())
Or create the database without associating it with the active document as :
using (Autodesk.AutoCAD.DatabaseServices.Database acDb = new Autodesk.AutoCAD.DatabaseServices.Database(false, true))
Balaji
