.NET
'End' substiture
3 REPLIES 3
junoj
489 Views, 3 Replies
'End' substiture
In vba it was very convenient to use “END” the exit a sub at any point. I have a lot of code that I am trying to translate to .net  . I was hopeful if I could find a “END” substitute so that I do not have to rewrite a lot of code.
Thank you in advance
3 REPLIES 3
arcticad
in reply to: junoj
You can use "Exit Sub" or "Return"
(defun botsbuildbots() (botsbuildbots))
BlackBox_
in reply to: junoj
You could also simply employ code logic which would preclude the processing of additional code if the appropriate test expression(s) are not satisfied.
"How we think determines what we do, and what we do determines what we get."
junoj
in reply to: junoj
Thank you both very much. Smiley Very Happy
”Boost
